Chris Dill
- Jan 1, 2014
I have scoured and scoured and tried different posts, different methods, etc, and none of them have worked.
I followed this guide to the letter: https://forums.freenas.org/index.php?threads/crashplan-on-freenas-9-3.26487/
Then after I tried to do it without SSH port forwarding and a tunnel, instead connecting right to my jail IP. Neither of these guides work because the new plugin and FreeNAS are different- for instance those java options are already fixed in the latest version.
Then I followed this guide: https://forums.freenas.org/index.ph...ashplan-4-4-1-on-older-freenas-9-2-1-7.38681/
And again, no dice (I followed both the OP and the comment at the end).
If anyone is bored with all the family in town this weekend, would you mind putting together a step by step for getting Crashplan headless on FreeNas 9.3 with the latest plugin version, and connecting to it from Windows using the latest Crashplan desktop version 4.4.1? I would be GREATLY in your debt!
I cannot post any logs for troubleshooting purposes, because I was never able to actually get it to connect... it actually connected, but under file locations the only thing there was my local PC C: and D:. Also. .ui_info doesnt exist on my PC with the new desktop version, though I do have some comparable files in two directories: C:\ProgramData\CrashPlan and C:\Program Files (x86)\CrashPlan.
