SOLVED Could not update in 9.3 Beta anymore
wkn
i am not able to succesfully update the 9.3 Beta anymore.
My current version is FreeNAS 9.3-BETA 2014-11-25 23:21:37 GMT
During Upgrade, i got error with No space left on device. I tried updating using the GUI, the CLI and a Manual Update, always same error after a few minutes of working.
BR
wkn
S
sef
Guest
Delete some of the boot environments. System > Boot > select a few and then click Delete.
I tend to leave the first one "default", and delete a few of the first ones after that.
wkn
Hi sef,
your suggestion did the job for me, all fine again.
Thanks,
wkn
rogerh
Hi sef,
As a matter of interest, can I ask what type and size is your boot device?
wkn
I am using a 4GB SATADOM for the boot device.
Intel(R) Celeron(R) CPU G1820T @ 2.40GHz, 8GB RAM, 3,5 TB Disk
S
sef
Guest
4G is going to be a bit small with 9.3 -- if you can, you may want to upgrade to a larger one.
(I've got a 4g satadom in one of my machines, I have a larger one; switching it out is going to bug the heck out of me because I won't have a way to transfer the configuration from one to the other except by saving the config, installing, and then restoring the config.)
