zeebee
 - Sep 18, 2019
I'm in the process of putting together my first FreeNAS build, and after doing some reading I'm now considering running under ESXi. This is primarily because I may want to run a Windows VM for XProtect (Security Camera Software), but it may also prove useful to have some desktop VMs for other purposes.
In reading the docs and various posts about ESXi, I think I need to purchase a HBA, but I'm still a little fuzzy on the details. Here's my current hardware:
Intel® Xeon® E-2136 Processor
Supermicro X11SCL-F Server Board
Crucial 16GB DDR4-2666 ECC UDIMM CT16G4WFD8266
Kingston AS400SSD 120G x 1 (boot)
Western Digital Red 4 TB 3.5" 5400RPM x 5 (pool)
Seasonic 650W Focus Plus
Fractal Design Define R6
I'm thinking if I buy the following HBA I can use PCI passthrough to give FreeNAS direct access to all the drives (1xSDD for boot, and 5xHDD for pool).
https://www.ebay.com.au/itm/LSI-6Gb...ode-ZFS-FreeNAS-unRAID-AU-seller/143058624384
I'd need to also buy another SSD to install ESXi which I could connect to one of the mobo's SATA ports.
Does this sound like I'm on the right track? Anything else about the above hardware that would be a problem for this setup?
Thanks for your advice.
