Configuration Cleanup
JustinHenne
I have been out of working with NAS setup for a while and due to a very rushed timeline that has just passed I am in the process of cleaning up the mess. This is also my first time working with TrueNAS.
Here is a short of the setup. The network is 100% offline. The 2 BNXT connections are configured with static IP's. All drives are in 1 RAID'd pool. That is connected to 3 Esxi servers (as a datastore) using NFS (all tied to the management IP). There are 2 not configured IGB NIC's that will not allow me to us the same subnet as the BNXT.
What I am looking to do is to setup the additional NIC's with IP's and move the management to one of them. Once that is done I would like to bond the 2 BNXT's together to allow for a faster connection and redundancy. If possible I want to keep all the IP's in the same grouping (meaning something like 192.x.x.100-103). With 192.x.x.100 and 101 being the management IGB and the 102,103 being the BNXT bonded datastore (NFS) connection
What I am looking for is any documentation/recommendations/insight that can point me in the right direction. Since this is already operational and I do have some data stored on the NAS I am working with caution.
Thanks in advance for any/all help.
Arwen
First off, unless the NICs are bonded into a LACP group, they can't be in the same sub-net.
Yes, you can make one of the 1Gbps NICs as a management NIC, but in a different sub-net as the 2 BNXT bonded NICs. With a bond / lagg / LACP you only need 1 IP address, though you can add more in the same sub-net as aliases.
Their are lots of Resources and sticky forum threads that can help. The Resources can be accessed at the top of any forum web page. Many Resource posts have discussion threads with additional information. The sticky forum threads are at the top of the sub-forum, in which they reside.
Here are some Resources related to your questions and configuration:
Since you are a new user to the forum, we don't know much about you, except what you wrote. It might be helpful for you to describe your hardware in details and your pool / configuration in detail as well. We have occasional new users that make configuration mistakes that are hard to correct later. But, early on would have been easier.
