Everything seems to be working fine now, though I'm still seeing the "can't disable some capabilities" statement in the log when starting the jail.
igb0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: IGB0
options=4a500b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,NOMAP>
ether 0c:c4:7a:02:49:54
inet 10.0.100.9 netmask 0xffff0000 broadcast 10.0.255.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4e507bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
ether 0c:c4:7a:02:49:55
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
vlan5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: vlan5
options=4600703<RXCSUM,TXCSUM,TSO4,TSO6,LRO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
groups: vlan
vlan: 5 vlanproto: 802.1q vlanpcp: 0 parent interface: igb1
status: active
vlan1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: vlan1
groups: vlan
vlan: 1 vlanproto: 802.1q vlanpcp: 0 parent interface: igb1
status: active
vlan99: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: vlan99
options=4200401<RXCSUM,LRO,RXCSUM_IPV6,NOMAP>
groups: vlan
vlan: 99 vlanproto: 802.1q vlanpcp: 0 parent interface: igb1
status: active
vlan11: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: vlan11
groups: vlan
vlan: 11 vlanproto: 802.1q vlanpcp: 0 parent interface: igb1
status: active
bridge5: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: bridge5
ether 58:9c:fc:00:48:4a
member: vlan5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 55
groups: bridge
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: bridge1
ether 58:9c:fc:00:27:30
member: vlan1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 55
groups: bridge
bridge99: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: bridge99
ether 58:9c:fc:10:ff:93
member: vnet0.21 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 19 priority 128 path cost 2000
member: vlan99 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 55
groups: bridge
bridge11: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: bridge11
ether 58:9c:fc:10:ff:9f
member: vlan11 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 55
groups: bridge
ether 58:9c:fc:10:1d:24
member: vnet0.9 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 23 priority 128 path cost 2000
member: vnet0.8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 17 priority 128 path cost 2000
member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 18 priority 128 path cost 2000
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 16 priority 128 path cost 2000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 15 priority 128 path cost 2000
member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 14 priority 128 path cost 2000000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
ether fe:a0:98:76:15:93
hwaddr 58:9c:fc:10:ff:d5
groups: tap
status: active
Opened by PID 2623
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: misc-apps as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:a5:a4:7e
hwaddr 02:b6:e8:06:c9:0a
groups: epair
status: active
vnet0.2: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: mariadb as nic: epair0b
options=8<VLAN_MTU>
ether 02:c4:7a:b6:a0:8b
hwaddr 02:5b:6d:62:35:0a
groups: epair
status: active
vnet0.4: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: programming as nic: epair0b
options=8<VLAN_MTU>
ether 02:c4:7a:cc:4c:72
hwaddr 02:d9:46:73:ab:0a
groups: epair
status: active
vnet0.8: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: nginx as nic: epair0b
options=8<VLAN_MTU>
ether 02:c4:7a:aa:70:0d
hwaddr 02:f5:40:ab:19:0a
groups: epair
status: active
vnet0.9: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: testpkg as nic: epair0b
options=8<VLAN_MTU>
ether 0e:c4:7a:2f:6c:28
hwaddr 02:70:d5:4d:5b:0a
groups: epair
status: active
vnet0.21: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: TesterVlan as nic: epair0b
options=8<VLAN_MTU>
ether 06:c4:7a:f0:9c:c5
hwaddr 02:68:1d:ca:aa:0a
groups: epair
status: active
