shackrock
- Dec 21, 2011
I did a scrub on my volume yesterday, please see the results below. Particularly I am wondering about the checksum errors (81) on the one disk as shown. Does that mean I need to replace it?
I did a zpool clear and it went back to zero...
Further, FreeNAS GUI says the volume is "HEALTHY" after the zpool clear. I should have checked it before that, but I didn't...whoops...
Now, I will add that I've ran this command to find out the real /dev/ device name:
and then I have attempted to run this as follows:
It's a SATA II drive connected directly to 1 of the motherboard's SATA ports.
[root@freenas] ~# zpool status
pool: DEC2010
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://www.sun.com/msg/ZFS-8000-9P
scan: scrub repaired 55K in 16h1m with 0 errors on Thu Apr 4 22:45:13 2013
NAME STATE READ WRITE CKSUM
DEC2010 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/218a2962-c5d4-11e0-8fd1-0025900d25b0 ONLINE 0 0 0
gptid/dc4978b8-ff57-11e1-88de-0025900d25b0 ONLINE 0 0 81
gptid/22b4bd1e-c5d4-11e0-8fd1-0025900d25b0 ONLINE 0 0 0
gptid/afb125e9-84f7-11e1-b8dd-0025900d25b0 ONLINE 0 0 0
gptid/b3dfe402-006c-11e2-acc4-0025900d25b0 ONLINE 0 0 0
gptid/23cc848c-c5d4-11e0-8fd1-0025900d25b0 ONLINE 0 0 0
raidz1-1 ONLINE 0 0 0
ada6p2.nop ONLINE 0 0 0
ada7p2.nop ONLINE 0 0 0
ada8p2.nop ONLINE 0 0 0
ada9p2.nop ONLINE 0 0 0
errors: No known data errors
[root@freenas] ~# zpool clear DEC2010
pool: DEC2010
state: ONLINE
gptid/dc4978b8-ff57-11e1-88de-0025900d25b0 ONLINE 0 0 0
[root@freenas] ~# glabel status
Name Status Components
gptid/218a2962-c5d4-11e0-8fd1-0025900d25b0 N/A ada0p2
gptid/dc4978b8-ff57-11e1-88de-0025900d25b0 N/A ada1p2
gptid/22b4bd1e-c5d4-11e0-8fd1-0025900d25b0 N/A ada2p2
gptid/afb125e9-84f7-11e1-b8dd-0025900d25b0 N/A ada3p2
gptid/b3dfe402-006c-11e2-acc4-0025900d25b0 N/A ada4p2
gptid/23cc848c-c5d4-11e0-8fd1-0025900d25b0 N/A ada5p2
ufs/FreeNASs3 N/A da0s3
ufs/FreeNASs4 N/A da0s4
ufs/FreeNASs1a N/A da0s1a
ufsid/50c8c7da3400b84f N/A da0s2a
ufs/FreeNASs2a N/A da0s2a
smartctl -a /dev/ada1p2 smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p6 amd64] (local build) Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net /dev/ada1p2: Unable to detect device type Smartctl: please specify device type with the -d option. Use smartctl -h to get a usage summary
