So the bad drive is back online, now it is recognized again and FreeNAS can read its label.
I did not see any SMART errors during POST.
[root@freenas] ~# dmesg
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p3 #7: Fri Sep 30 12:51:49 PDT 2011
jpaetzel@servant.iXsystems.com:/b/sf_freenas_build/obj.amd64/b/sf_freenas_build/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Atom(TM) CPU D525 @ 1.80GHz (1799.97-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x106ca Family = 6 Model = 1c Stepping = 10
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x40e31d<SSE3,DTES64,MON,DS_CPL,TM2,SSSE3,CX16,xTPR,PDCM,MOVBE>
AMD Features=0x20100800<SYSCALL,NX,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 4294967296 (4096 MB)
avail memory = 4083167232 (3894 MB)
ACPI APIC Table: <GBT GBTUACPI>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 HTT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP/HT): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP/HT): APIC ID: 3
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
netsmb_dev: loaded
cryptosoft0: <software crypto> on motherboard
acpi0: <GBT GBTUACPI> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, bf4e0000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xff00-0xff07 mem 0xfdf00000-0xfdf7ffff,0xd0000000-0xdfffffff,0xfdd00000-0xfddfffff irq 16 at device 2.0 on pci0
agp0: <Intel Pineview SVGA controller> on vgapci0
agp0: detected 8188k stolen memory
agp0: aperture size is 256M
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
re0: <RealTek 8168/8111 B/C/CP/D/DP/E PCIe Gigabit Ethernet> port 0xee00-0xeeff mem 0xfdcff000-0xfdcfffff,0xfdcf8000-0xfdcfbfff irq 16 at device 0.0 on pci1
re0: Using 1 MSI-X message
re0: Chip rev. 0x2c000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 6c:f0:49:de:8d:09
re0: [ITHREAD]
pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.1 on pci0
pci2: <ACPI PCI bus> on pcib2
ahci0: <JMicron JMB363 AHCI SATA controller> mem 0xfdefe000-0xfdefffff irq 17 at device 0.0 on pci2
ahci0: [ITHREAD]
ahci0: AHCI v1.00 with 2 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
atapci0: <JMicron JMB363 UDMA133 controller> port 0xdf00-0xdf07,0xde00-0xde03,0xdd00-0xdd07,0xdc00-0xdc03,0xdb00-0xdb0f irq 18 at device 0.1 on pci2
atapci0: [ITHREAD]
ata2: <ATA channel 0> on atapci0
ata2: [ITHREAD]
uhci0: <Intel 82801G (ICH7) USB controller USB-A> port 0xfe00-0xfe1f irq 23 at device 29.0 on pci0
uhci0: [ITHREAD]
usbus0: <Intel 82801G (ICH7) USB controller USB-A> on uhci0
uhci1: <Intel 82801G (ICH7) USB controller USB-B> port 0xfd00-0xfd1f irq 19 at device 29.1 on pci0
uhci1: [ITHREAD]
usbus1: <Intel 82801G (ICH7) USB controller USB-B> on uhci1
uhci2: <Intel 82801G (ICH7) USB controller USB-C> port 0xfc00-0xfc1f irq 18 at device 29.2 on pci0
uhci2: [ITHREAD]
usbus2: <Intel 82801G (ICH7) USB controller USB-C> on uhci2
uhci3: <Intel 82801G (ICH7) USB controller USB-D> port 0xfb00-0xfb1f irq 16 at device 29.3 on pci0
uhci3: [ITHREAD]
usbus3: <Intel 82801G (ICH7) USB controller USB-D> on uhci3
ehci0: <Intel 82801GB/R (ICH7) USB 2.0 controller> mem 0xfdfff000-0xfdfff3ff irq 23 at device 29.7 on pci0
ehci0: [ITHREAD]
usbus4: EHCI version 1.0
usbus4: <Intel 82801GB/R (ICH7) USB 2.0 controller> on ehci0
pcib3: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci3: <ACPI PCI bus> on pcib3
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci1: <Intel ICH7 AHCI SATA controller> port 0xfa00-0xfa07,0xf900-0xf903,0xf800-0xf807,0xf700-0xf703,0xf600-0xf60f mem 0xfdffe000-0xfdffe3ff irq 19 at device 31.2 on pci0
ahci1: [ITHREAD]
ahci1: AHCI v1.10 with 4 3Gbps ports, Port Multiplier not supported
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich3: [ITHREAD]
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich4: [ITHREAD]
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich5: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart1: [FILTER]
ppc0: <Parallel port> port 0x378-0x37f irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
ppc0: [ITHREAD]
ppbus0: <Parallel port bus> on ppc0
lpt0: <Printer> on ppbus0
lpt0: [ITHREAD]
lpt0: Interrupt-driven port
orm0: <ISA Option ROM> at iomem 0xd0000-0xd2fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
coretemp0: Can not get Tj(target) from your CPU, using 100C.
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
coretemp1: Can not get Tj(target) from your CPU, using 100C.
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
coretemp2: Can not get Tj(target) from your CPU, using 100C.
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
coretemp3: Can not get Tj(target) from your CPU, using 100C.
p4tcc3: <CPU Frequency Thermal Control> on cpu3
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <Intel> at usbus4
uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub4: 8 ports with 8 removable, self powered
ugen4.2: <Kingston> at usbus4
umass0: <Kingston DataTraveler G3, class 0/0, rev 2.00/1.00, addr 2> on usbus4
ada0 at ahcich1 bus 0 scbus1 target 0 lun 0
ada0: <SAMSUNG HD204UI 1AQ100da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
da0: <Kingston DataTraveler G3 PMAP> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 7429MB (15215808 512 byte sectors: 255H 63S/T 947C)
01> ATA-8 SATA 2.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich2 bus 0 scbus3 target 0 lun 0
ada1: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version 4
ZFS storage pool version 15
re0: link state changed to UP
I'm not sure what to make of it. Is the data back to a normal state?
The manufacturing date is 2011.7 and one of the labels says SEC-HD204UI(B) so I understand the drive is patched. Should I patch again just in case?
I called the shop and they said they can run a test on it and if it will pass they will not replace it.
Should I try my luck? I would not want to replace a good drive with a refurbished one.
