I have the latest version of FreeNas with the NextCloud plugin installed.
I would like to understand how to change the http and https ports of the NextCloud so as to bring it to reach: new port.
Thank You.
ok, I found the configuration file Nextcloud tells me that the domain is not reliable but it is already added to the list of domains.
is it possible that the proxy reverce accesses with another address to nextcloud? how do i know which one?
Don’t alter the plugin itself. Let that be what it is and install the proxy in its own jail? By messing with the plugin you will potentially break updates. There is virtually no overhead penalty for running multiple jails as with multiple VMs
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
