Can't stop Webdav
Ismael Duarte
Hi all
Since 9.3 beta I can't find a way to stop webdav service.
I see a windows where I can read something like "Webdav service can't be stopped"
In the log it's possible to read:
Dec 30 19:38:38 duarte notifier: Stopping apache24.
Dec 30 19:38:38 duarte notifier: Waiting for PIDS: 2786.
Dec 30 19:38:38 duarte notifier: Will not 'restart' apache24 because apache24_enable is NO.
Dec 30 19:39:02 duarte notifier: Performing sanity check on apache24 configuration:
Dec 30 19:39:02 duarte notifier: Syntax OK
Dec 30 19:39:02 duarte notifier: apache24 not running? (check /var/run/httpd.pid).
Dec 30 19:39:13 duarte notifier: apache24 not running? (check /var/run/httpd.pid).
Dec 30 19:39:13 duarte notifier: Will not 'restart' apache24 because apache24_enable is NO.
Scharbag
I too have this bug.
Ismael Duarte
Solved.
I've some jails and plugins (Plex and a jail with apache installed). Stopped everything, both jails and plex, after that it was possible to stop webdav service easily.
Maybe not a solution, but a good workaround.
kloon
I have to turn off my owncloud to stop the WebDav service. I think as the bug feedback, there might be some jails that sharing the same process name which cause the problem. Guess that I have to stop the WebDav until developer come up with solution or fix.
