Can't start Plex after upgrade
Toydoll
Hi
So let's make this a long story short:
1. I upgraded freenas from 11.2 to 11.3U1
Worked fine.
2. Upgraded the jails from 11.2 to 11.3
Did not work at first but after som help from the forum it went well.
3. Upgraded Plex from 1.15.something to the latest, 1.19.1.2589
Did not work at first, see this thread. Managed to get it to work eventually by entering "pkg bootstrap -f".
Now my problem is that I can't get Plex to work, at all. I've tried restarting the iocage and the service, even the whole machine. That did not help.
What little info I can give you:
When I enter "service plexmediaserver_plexpass start" it says:
Starting plexmediaserver_plexpass.
And yet, when I enter "service plexmediaserver_plexpass status" I get
plexmediaserver_plexpass is not running.
I have made no other changes on Freenas.
Freenas version: 11.3-U1
I don't know which logs are of use so... here are three that might or might not be relevant.
/usr/local/plexdata-plexpass/Plex Media Server/Logs/Plex Media Server.log
This one has a ton of line in it uring the last minutes. I'll copy the last ones, let me know if the earlier ones are of any use.
Note: The timestamps in the log are from around the time I updated Plex (can't tell if it was before or after). Meaning that it says nothing about my tries to get it to work from today.
Apr 05, 2020 02:45:49.238 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:45:51.245 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:45:53.256 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:45:55.259 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:45:57.291 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:45:59.299 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:01.305 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:03.349 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:05.352 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:07.352 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:08.179 [0x80c653300] DEBUG - Completed: [192.168.1.113:60307] -2 GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) TLS GZIP 20009ms 5 bytes (pipelined: 225)
Apr 05, 2020 02:46:08.187 [0x80c652e00] DEBUG - Auth: authenticated user 1 as sebkar
Apr 05, 2020 02:46:08.187 [0x80d027d00] DEBUG - Request: [192.168.1.113:60307 (Allowed Network)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) TLS GZIP Signed-in Token (sebkar)
Apr 05, 2020 02:46:09.377 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:11.379 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:13.381 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99"
Apr 05, 2020 02:46:14.337 [0x80bcd2f00] DEBUG - Shutting down with signal 15 (Terminated)
/Plex/root/var/log/messages
Last login: Sun Apr  5 12:22:13 on ttys001
/Volumes/iocage/jails/Plex/root/var/log/messages ; exit;
Sebastians-MBP:~ sebastian$ /Volumes/iocage/jails/Plex/root/var/log/messages ; exit;
/Volumes/iocage/jails/Plex/root/var/log/messages: line 1: Jan: command not found
...more of the same lines...
/Volumes/iocage/jails/Plex/root/var/log/messages: line 24: Apr: command not found
/Volumes/iocage/jails/Plex/root/var/log/messages: line 25: syntax error near unexpected token `('
/Volumes/iocage/jails/Plex/root/var/log/messages: line 25: `Apr  5 03:19:38 Plex root: /usr/sbin/service: WARNING: $growfs_enable is not set properly - see rc.conf(5).'
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
/iocage/log/Plex-console
Sun Apr  5 12:10:18 CEST 2020
Stopping cron.
Waiting for PIDS: 18487.
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib
32-bit compatibility ldconfig path: /usr/lib32
Setting hostname: Plex.
Starting Network: lo0 epair0b.
    options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether ac:1f:6b:31:41:eb
    hwaddr 02:69:d0:00:06:0b
    inet 192.168.1.3 netmask 0xffffff00 broadcast 192.168.1.255
    nd6 options=1<PERFORMNUD>
    status: active
    groups: epair
add host 127.0.0.1: gateway lo0 fib 0: route already in table
add host ::1: gateway lo0 fib 0: route already in table
add net fe80::: gateway ::1
add net ff02::: gateway ::1
add net ::ffff:0.0.0.0: gateway ::1
add net ::0.0.0.0: gateway ::1
Creating and/or trimming log files.
Starting syslogd.
Clearing /tmp (X related).
Updating motd:.
Starting cron.
Sun Apr  5 12:33:50 CEST 2020
It's a good thing this community is so nice, I have no idea how I would survive otherwise, so thanks!
It's probably quicker to just make a new Plex jail and copy your data over (or better still separate it out of the jail if you didn't already).
Yorick
That. Use danb35's script, or my fork of it (I think mine works better on 11.3); use the instructions on the forums to rsync your metadata over.
I am literally now putting the finishing touches on a video about that. If I can figure out YouTube, that should be available tonight, in roughly 8-10 hours.
anmnz
FWIW: I had the same problem yesterday after upgrading Plex and fixed it with pkg install libidn2 in the Plex jail.
I turned up rc.conf logging in the jail, found an error message saying curl couldn't run because the libidn2 library was missing, installed the package, and Plex started and has been behaving normally.
(I'm only mentioning this in case it's of interest, not as a recommendation. I shall be rebuilding the Plex jail from scratch as I don't want it in this odd state where I don't really know why it broke or what might break next time...)
Looks like there is a problem with the 1.19.1.2589 package. A workaround is to downgrade back to 1.18.8.2527. I'm using @danb35's script. This is what I had to do to revert back.
Shell into the Plex jail.
To see the version of Plex installed:
pkg info plexmediaserver-plexpass
It should indicate version 1.19.1.2589.
Delete the installed package:
pkg delete plexmediaserver-plexpass
The previous packages are located in /var/cache/pkg.
cd /var/cache/pkg
ls
You should see the previous version 1.18.8.2527 (or maybe a slightly later version). Install it.
pkg add plexmediaserver-plexpass-1.18.8.2527.txz
Start the plex service (note the underscore instead of the dash):
Plex should now be operating again on the previous version.
EDIT: I'm not sure what the process is to report package issues, but there's quite a lot of detail about the issue in this Plex forum thread.
Spiceman
I had same issue with latest Plex pkg. I just rolled it back to my latest jail snapshot.
Jailer
Not strong, but bad
Yorick
Plexmediaserver-plexpass is the beta code. If you want things to be stable, stick with Plexmediaserver.
Spiceman
That is interesting. I guess i missed that somewhere. Is there a reference or something that plexmediaserver-plexpass is beta? Is that a Plex decision or ?
Not questioning your statement or anything, i just try to stay informed...lol
Yorick
@Spiceman Its just how the package maintainers have labeled things.
plexpass enables several things, among them access to beta code.
From a license standpoint, you need a plexpass sub to download the beta releases. FreeBSD maintainer packages it as plexmediaserver-plexpass.
With or without a PlexPass, the stable code is available, and it is packaged as plexmediaserver. Of course you can use all PlexPass features on stable code.
See https://www.plex.tv/media-server-downloads/ for the two FreeBSD versions, and https://support.plex.tv/articles/201844613-early-access-beta-releases/ for a discussion of beta releases.
Edit: FreeNAS is now clearer about this in the plugin list since 11.3.
Spiceman
@Yorick Interesting. Thanks for the info.
NasKar
I wish I found this thread earlier. The fix I used was to comment out
#iocage exec "${JAIL_NAME}" cp /etc/pkg/FreeBSD.conf /usr/local/etc/pkg/repos/
#iocage exec "${JAIL_NAME}" sed -i '' "s/quarterly/latest/" /usr/local/etc/pkg/repos/FreeBSD.conf
#iocage exec "${JAIL_NAME}" rm -rf /configs
#iocage exec "${JAIL_NAME}" pkg upgrade -y
lines in the script to prevent it from getting the latest version.
Yorick
You can also instruct the script to fetch the stable version, by leaving the PLEXPASS variable at 0, and you won't run into this issue.
gdog0
Just chiming in, my CRON updated last night and plexmediaserver-plexpass wasn't working this morning. Did a bunch of somewhat blind troubleshooting and googling to no avail. Rolled back my snapshot and it was right back up.
I then saw this:
Ran:
pkg install p5-Locale-libintl
pkg install libidn2
Then updated and restarted and it's working now on the newer version.
Jailer
Not strong, but bad
Ran:
pkg install libidn2
This would be good info to forward to Feld so he can fix the port.
Yorick
plexmediaserver, the stable pkg, was promoted to plexmediaserver-1.18.9.2578 this Sunday. Updated itself automatically (because danb35's script with auto-update), and kept running.
I get the desire for new versions, I do, and - beta code for a Plex that's not a pure testing instance? I'm surprised at folk running plexmediaserver-plexpass as their daily driver.
Don't be too surprised. Some of us are also beta testers for Plex ;)
hertzsae
I believe the reason for the beta version being called plexmediaserver-plexpass is that the plex team used to release two wholly different binaries for free users and plexpass users. If you wanted plexpass features or beta installs, you needed to install the plexpass version. Fairly long ago, they improved it, so that both binaries had plexpass features as long as you logged into it with a plexpass account. Now the only reason to install the plexpass binary is to beta test.
