Hi
So let's make this a long story short:
1. I upgraded freenas from 11.2 to 11.3U1
Worked fine.
2. Upgraded the jails from 11.2 to 11.3
Did not work at first but after som help from the forum it went well.
3. Upgraded Plex from 1.15.something to the latest, 1.19.1.2589
Did not work at first, see this thread. Managed to get it to work eventually by entering "pkg bootstrap -f".
Now my problem is that I can't get Plex to work, at all. I've tried restarting the iocage and the service, even the whole machine. That did not help.
What little info I can give you:
When I enter "service plexmediaserver_plexpass start" it says:
And yet, when I enter "service plexmediaserver_plexpass status" I get
I have made no other changes on Freenas.
Freenas version: 11.3-U1
I don't know which logs are of use so... here are three that might or might not be relevant.
It's a good thing this community is so nice, I have no idea how I would survive otherwise, so thanks!
Worked fine.
Starting plexmediaserver_plexpass.
plexmediaserver_plexpass is not running.
/usr/local/plexdata-plexpass/Plex Media Server/Logs/Plex Media Server.log
This one has a ton of line in it uring the last minutes. I'll copy the last ones, let me know if the earlier ones are of any use.
Note: The timestamps in the log are from around the time I updated Plex (can't tell if it was before or after). Meaning that it says nothing about my tries to get it to work from today.
/Plex/root/var/log/messages
/iocage/log/Plex-console
Apr 05, 2020 02:45:49.238 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:45:51.245 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:45:53.256 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:45:55.259 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:45:57.291 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:45:59.299 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:01.305 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:03.349 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:05.352 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:07.352 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:08.179 [0x80c653300] DEBUG - Completed: [192.168.1.113:60307] -2 GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) TLS GZIP 20009ms 5 bytes (pipelined: 225) Apr 05, 2020 02:46:08.187 [0x80c652e00] DEBUG - Auth: authenticated user 1 as sebkar Apr 05, 2020 02:46:08.187 [0x80d027d00] DEBUG - Request: [192.168.1.113:60307 (Allowed Network)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) TLS GZIP Signed-in Token (sebkar) Apr 05, 2020 02:46:09.377 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:11.379 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:13.381 [0x80ca5a900] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99", couldn't check file: "/usr/local/share/plexmediaserver-plexpass/Resources/Plug-ins-782228f99" Apr 05, 2020 02:46:14.337 [0x80bcd2f00] DEBUG - Shutting down with signal 15 (Terminated)
Last login: Sun Apr 5 12:22:13 on ttys001
/Volumes/iocage/jails/Plex/root/var/log/messages ; exit;
Sebastians-MBP:~ sebastian$ /Volumes/iocage/jails/Plex/root/var/log/messages ; exit;
/Volumes/iocage/jails/Plex/root/var/log/messages: line 1: Jan: command not found
...more of the same lines...
/Volumes/iocage/jails/Plex/root/var/log/messages: line 24: Apr: command not found
/Volumes/iocage/jails/Plex/root/var/log/messages: line 25: syntax error near unexpected token `('
/Volumes/iocage/jails/Plex/root/var/log/messages: line 25: `Apr 5 03:19:38 Plex root: /usr/sbin/service: WARNING: $growfs_enable is not set properly - see rc.conf(5).'
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Sun Apr 5 12:10:18 CEST 2020
Stopping cron.
Waiting for PIDS: 18487.
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib
32-bit compatibility ldconfig path: /usr/lib32
Setting hostname: Plex.
Starting Network: lo0 epair0b.
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether ac:1f:6b:31:41:eb
hwaddr 02:69:d0:00:06:0b
inet 192.168.1.3 netmask 0xffffff00 broadcast 192.168.1.255
nd6 options=1<PERFORMNUD>
status: active
groups: epair
add host 127.0.0.1: gateway lo0 fib 0: route already in table
add host ::1: gateway lo0 fib 0: route already in table
add net fe80::: gateway ::1
add net ff02::: gateway ::1
add net ::ffff:0.0.0.0: gateway ::1
add net ::0.0.0.0: gateway ::1
Creating and/or trimming log files.
Starting syslogd.
Clearing /tmp (X related).
Updating motd:.
Starting cron.
Sun Apr 5 12:33:50 CEST 2020
