I have a pool of just 1 disk for cctv , which has been in use for about 7 years now. It is now reported as being Unhealthy in the list of pools, and it i unreadable. I can't access any data on it now since 2 days ago.
After reading up on how to replace the disk with the same size, I found I can't put it offline.
I get this when trying to do so:
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 232, in __zfs_vdev_operation
op(target, *args)
File "libzfs.pyx", line 402, in libzfs.ZFS.__exit__
op(target, *args)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 248, in <lambda>
self.__zfs_vdev_operation(name, label, lambda target: target.offline())
File "libzfs.pyx", line 2203, in libzfs.ZFSVdev.offline
libzfs.ZFSException: pool I/O is currently suspended
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 246, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 111, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 248, in offline
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 234, in __zfs_vdev_operation
raise CallError(str(e), e.code)
middlewared.service_exception.CallError: [EZFS_POOLUNAVAIL] pool I/O is currently suspended
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 139, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1236, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1146, in offline
await self.middleware.call('zfs.pool.offline', pool['name'], found[1]['guid'])
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1279, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1244, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1250, in _call_worker
Help please
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1169, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor
This is the ouput of zpool ststus for the said disk
I have tried Scrub Pool, but get this error:
op(target, *args)
op(target, *args)
Help please
NAME STATE READ WRITE CKSUM CCTV ONLINE 0 0 0 gptid/d647d843-4792-11e6-a4b6-0cc47a0c1eef ONLINE 4 284 0 errors: List of errors unavailable: pool I/O is currently suspended
