Can't join Active Directory,Failed to validate bind credentials: [EFAULT] timed out
freenaslol
FreeNas 11.3 new install;
ESXI 6.5 ENV;
Windows 2012 R2 AD;
AD time out up to 90;
AD Account is correct;
ping AD Server is OK; ping NAS's HostName(xxxx.domain.com) is OK;
Does anyone know why?
anodos
Sambassador
You can PM me /var/log/middlewared.log. This is probably a case of the LDAP bind timing out. We set the NETWORK_TIMEOUT value for ldap.conf based on "dns_timeout". ldap.set_option(ldap.OPT_NETWORK_TIMEOUT, self.ad['dns_timeout']). You can try increasing it.
acarmona
Hi, Bro!
/vat/log/middlewared.log
(DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
What can I try bro?
freenaslol
Hi, anodos
AD Timeout, DNS Timeout up to 60;
The problems remain ;
[2020/02/14 11:16:10] (DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
[2020/02/14 11:28:55] (DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
[2020/02/14 11:30:33] (DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
[2020/02/14 11:31:13] (DEBUG) ServiceService._simplecmd():287 - Calling: start(ssh)
[2020/02/14 11:31:13] (DEBUG) EtcService.generate():274 - No new changes for /etc/local/ssh/sshd_config
[2020/02/14 11:31:40] (DEBUG) ServiceService._simplecmd():287 - Calling: reload(ssh)
[2020/02/14 11:37:19] (DEBUG) ServiceService._simplecmd():287 - Calling: start(lldp)
[2020/02/14 11:37:34] (DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
[2020/02/14 11:37:40] (DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
[2020/02/14 11:38:06] (DEBUG) ServiceService._simplecmd():287 - Calling: stop(lldp)
[2020/02/14 11:39:02] (DEBUG) EtcService.generate():274 - No new changes for /etc/krb5.conf
  • middlewared.zip
tfili
Whats about DNS entries for the domain ? Are you able to ping the domain ? ... not the AD
Do you use the AD as the first nameserver ?
Do you have tried to join from cli with net ads join -U adminuser ?
acarmona
I can send a ping correctly.
My AD is the first nameserver.
net ads join -U freenasadmin:
Failed to join domain: This operation is only allowd for the PDC of the domain
My ad is PDC
tfili
Is it posible to get a kerberos ticket ? : kinit freenasadmin
Whats about firewall related problems ?
Is the ESXi in the same network / VLAN than the AD or do you use NAT ?
acarmona
This is correct?
The servers share the same VLAN.
My english is very bad, sorry.
anodos
Sambassador
Turn on "verbose logging", and run the following commands:
midclt call activedirectory.update '{"enable": false}'
midclt call activedirectory.update '{"enable": true}'
and upload the middlewared log.
anodos
Sambassador
Try the following:
midclt call activedirectory.update '{"enable": true, "verbose_logging": true, "dns_timeout": 30}'
This looks suspiciously like we're hitting the a timeout for middleware calls. If this is the case then it looks like the environment is taking over 60 seconds complete an LDAP bind. You may want to also review logs on your AD DC.
MikeUK
Acarmona, did you ever get this to work? as I had similar issues but never got it to work. But it worked fine on 11.2.7
