Sprint
- Mar 30, 2019
Hi All
So I'm starting to play with TrueNas Scale on my offsite backup NAS, as it should do everything I need, so decided I'd try and help with the development. I was running TrueNas Core in a VM on ESX, so I exported my two pools and wiped the OS drives that ESX lived on, and installed TrueNas scale. I then have gone to import my two pools. One was relatively new, and was encrypted under TrueNas (That has imported) but my main backup pool isn't visible when I go to "import". the only difference is that this was encrypted back when the server was still using FreeNas, so "Legacy Encryption" I guess? Could this be a known bug? (I did search around before posting but didn't find anything). All input welcome, and if its not something anyones come across, then I'll maybe try raise it as a bug :)
Thanks all
Sprint
Thanks all
Sprint
