SOLVED Can't connect to TrueNAS with 2FA activated
infraerik
Hi there,
Just a quick note that I can't seem to get TrueCommand to connect to a TrueNAS install that has 2FA activated. Fresh install of 1.3.2 in a Docker container. It does connect to instances without 2FA perfectly well.
You probably need to use an API Key for it instead...
Generate one on the FreeNAS from the cog wheel in the top right of the GUI | API Keys, then se it instead of the password.
infraerik
Aha ! I hadn't found out where to generate them from the "client" TrueNAS side of things. That did the trick !
