Could this be because I have ISCSI and CIFS on the same ZPOOL? I carved out 1TB for ISCSI which is working swimmingly, now i'm trying to share out CIFS and the permissions aren't setting. Mind you it let me create the share and I can READ it..
Perhaps, but as I have found out I cannot change any permissions which is a larger problem. I tried to give the "nobody" account write permissions. It says it's successful but nothing changes.
Getting very frustrated, Tried a few different versions of Freenas as well.
Duno what command is called from GUI (cant check now) but it will be something like " su - root -c "chmod *** blabla" " or maybe " sudo su - root -c "chmod *** blabla" " so maybe there is a password mishmash between gui and root behind. Anyway in this case nothing shoul work. Try to create/delete new user for example. Is it working? Can you see any error messages bottom of the screen?
Windows type of ACL is mutually exclusive, Windows type of ACL is not supported by the GUI, once you set it to Windows ACL you have to manage them from Windows.
Thanks!!!! That was it. I had set the ACL to Windows. once I change the ACL back to unix the permissions worked as expected. I was troubleshooting another problem I am having with setting the permissions on a CIFS share.
