antiartist
- Dec 5, 2012
Cannot send a test email from the general settings menu. The error is:
My ISP is Telus (Canada) and so I'm using their SMTP address. To use the relay, you have to be on their network (which I am) and as such, they do not require authentication credentials:
From the FreeNAS shell, I can successfully ping both the IP address and freenas.local and just "freenas".
From Windows shell (on a seperate computer within the local network) I can successfully ping the freenas IP address, "freenas" but NOT freenas.local
In the Freenas Global Configuration, I have tried leaving the Nameserver field blank and using the telus nameservers*
I did a reverse IP lookup of smtp.telus.net and found the IP address to be 199.185.220.249
Replacing the smtp hostname with the IP address and testing, I get a new error:
Soooooooo....I have a DNS issue?
Before posting this, I have definitely searched through this forum looking for an answer. While I'm certainly not the only person that has had this problem, the threads I did find are either specific to gmail smtp settings (which doesn't apply here) or the problem magically fixes itself (which has yet to happen!).
Your help is appreciated!
Your test email could not be sent: [Errno 8] hostname nor servname provided, or not known
smtp.telus.net:25
Your test email could not be sent: [Errno 51] Network is unreachable
