Cannot see Transmission mount point in nextcloud
diggerydoo
I installed transmission and set the mount point to a folder inside the mount point for nextcloud, but cannot see the folder in nextcloud.
Nextcloud isn't designed to deal with other software adding/removing/changing files. Unless you specifically set up Nextcloud to deal with external files, if Nextcloud didn't put the files there, it won't know about them.
diggerydoo
It seems to handle file management from the share set in the same place in the mount point just fine though
