CAM status: ATA Status Error
kck
4 years stable FreeNAS, suddenly got problem on my WD30EFRX Hard drive.
Recently, I cannot access the volume, the following is the error message.
Any chance to get back my data in the Hard drive! There is no backup :(
Please help!
FreeBSD 10.3-STABLE (FreeNAS.amd64)
(ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 00 00 00 40 00 00 00 01 00 00
(ada2:ahcich2:0:0:0): CAM status: ATA Status Error
(ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC )
(ada2:ahcich2:0:0:0): RES: 41 40 00 00 00 40 00 00 00 00 00
(ada2:ahcich2:0:0:0): Retrying command
smartctl -a -q noserial /dev/ada2
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed: read failure	   90%	 33494		 0
# 2  Extended offline	Completed: read failure	   90%	 33481		 0
# 3  Extended offline	Completed: read failure	   90%	 33479		 0
# 4  Extended offline	Completed: read failure	   90%	 33479		 0
I already checked and replaced SATA cable connections. no luck :(
As per the forum rules, what's the hardware? And what is the output of zpool status and of smartctl -x /dev/adaX, for all drives? [CODE][/CODE] tags for all console output, please.
kck
Build FreeNAS-9.10.2-U3 (e1497f269)
Platform AMD Turion(tm) II Neo N40L Dual-Core Processor
Memory 1889MB
ada2 is having problem. The rest of the Disk are okay. ada2 configured as no RAID
zpool status
pool: Volume1
 state: ONLINE
  scan: scrub repaired 0 in 2h37m with 0 errors on Sun Apr  2 02:37:20 2017
	NAME											STATE	 READ WRITE CKSUM
	Volume1										 ONLINE	   0	 0	 0
	  mirror-0									  ONLINE	   0	 0	 0
		gptid/36ab72c8-5262-11e2-b0e5-a0b3cce95132  ONLINE	   0	 0	 0
		gptid/2a07b8ae-5268-11e2-8990-a0b3cce95132  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h16m with 0 errors on Sun Apr  2 04:01:16 2017
	freenas-boot  ONLINE	   0	 0	 0
	  da0p2	 ONLINE	   0	 0	 0
smartctl -x /dev/ada2
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD30EFRX-68AX9N0
Serial Number:	WD-WMC1T0615162
LU WWN Device Id: 5 0014ee 6ad7b4580
Firmware Version: 80.00A80
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:	Sun Apr 30 22:48:49 2017 MYT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
Self-test execution status:	  (   0)	The previous self-test routine completed
					been run.
data collection:		 (41760) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	 (   2) minutes.
Extended self-test routine
recommended polling time:	 ( 418) minutes.
Conveyance self-test routine
recommended polling time:	 (   5) minutes.
SCT capabilities:			(0x70bd)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   197   197   051	-	36031
  3 Spin_Up_Time			POS--K   185   176   021	-	5708
  4 Start_Stop_Count		-O--CK   100   100   000	-	87
  5 Reallocated_Sector_Ct   PO--CK   190   190   140	-	318
  7 Seek_Error_Rate		 -OSR-K   200   200   000	-	0
  9 Power_On_Hours		  -O--CK   055   055   000	-	33505
 10 Spin_Retry_Count		-O--CK   100   253   000	-	0
 11 Calibration_Retry_Count -O--CK   100   253   000	-	0
 12 Power_Cycle_Count	   -O--CK   100   100   000	-	87
192 Power-Off_Retract_Count -O--CK   200   200   000	-	38
193 Load_Cycle_Count		-O--CK   200   200   000	-	48
194 Temperature_Celsius	 -O---K   115   111   000	-	35
196 Reallocated_Event_Count -O--CK   172   172   000	-	28
197 Current_Pending_Sector  -O--CK   200   200   000	-	30
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   100   253   000	-	0
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS	   1  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 33203 (device log contains only the most recent 24 errors)
	CR	 = Command Register
	FEATR  = Features Register
	COUNT  = Count (was: Sector Count) Register
	LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
	LH	 = LBA High (was: Cylinder High) Register	]   LBA
	LM	 = LBA Mid (was: Cylinder Low) Register	  ] Register
	LL	 = LBA Low (was: Sector Number) Register	 ]
	DV	 = Device (was: Device/Head) Register
	DC	 = Device Control Register
	ER	 = Error register
	ST	 = Status register
Error 33203 [10] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 00 00 02 00 40 00  Error: UNC at LBA = 0x00000200 = 512
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  c8 00 00 00 00 00 00 00 00 02 00 40 08	 00:08:40.203  READ DMA
  c8 00 00 00 00 00 00 00 00 02 00 40 08	 00:08:37.228  READ DMA
  c8 00 00 00 00 00 00 00 00 02 00 40 08	 00:08:34.242  READ DMA
  c8 00 00 00 00 00 00 00 00 02 00 40 08	 00:08:31.334  READ DMA
  c8 00 00 00 00 00 00 00 00 02 00 40 08	 00:08:28.663  READ DMA
Error 33202 [9] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  2f 00 00 00 01 00 00 00 00 00 10 40 08	 00:08:28.661  READ LOG EXT
Error 33201 [8] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  60 01 00 00 f8 00 00 00 00 00 00 40 08	 00:08:25.832  READ FPDMA QUEUED
Error 33200 [7] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  2f 00 00 00 01 00 00 00 00 00 10 40 08	 00:08:25.831  READ LOG EXT
Error 33199 [6] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  60 01 00 00 e8 00 00 00 00 00 00 40 08	 00:08:23.001  READ FPDMA QUEUED
Error 33198 [5] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  40 -- 51 00 00 00 00 00 00 00 00 40 00  Error: UNC at LBA = 0x00000000 = 0
  2f 00 00 00 01 00 00 00 00 00 10 40 08	 00:08:23.000  READ LOG EXT
  60 01 00 00 d8 00 00 00 00 00 00 40 08	 00:08:20.182  READ FPDMA QUEUED
Error 33197 [4] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  2f 00 00 00 01 00 00 00 00 00 10 40 08	 00:08:20.181  READ LOG EXT
  60 01 00 00 c8 00 00 00 00 00 00 40 08	 00:08:17.341  READ FPDMA QUEUED
Error 33196 [3] occurred at disk power-on lifetime: 33504 hours (1396 days + 0 hours)
  2f 00 00 00 01 00 00 00 00 00 10 40 08	 00:08:17.339  READ LOG EXT
  60 01 00 00 b8 00 00 00 00 00 00 40 08	 00:08:14.215  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					35 Celsius
Power Cycle Min/Max Temperature:	 27/35 Celsius
Lifetime	Min/Max Temperature:	 27/39 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (75)
Index	Estimated Time   Temperature Celsius
  76	2017-04-30 14:51	35  ****************
 ...	..( 40 skipped).	..  ****************
 117	2017-04-30 15:32	35  ****************
 118	2017-04-30 15:33	34  ***************
 ...	..( 69 skipped).	..  ***************
 188	2017-04-30 16:43	34  ***************
 189	2017-04-30 16:44	 ?  -
 190	2017-04-30 16:45	27  ********
 191	2017-04-30 16:46	28  *********
 192	2017-04-30 16:47	29  **********
 193	2017-04-30 16:48	30  ***********
 194	2017-04-30 16:49	30  ***********
 195	2017-04-30 16:50	30  ***********
 196	2017-04-30 16:51	31  ************
 197	2017-04-30 16:52	31  ************
 198	2017-04-30 16:53	31  ************
 199	2017-04-30 16:54	32  *************
 ...	..(  2 skipped).	..  *************
 202	2017-04-30 16:57	32  *************
 203	2017-04-30 16:58	33  **************
 ...	..(  2 skipped).	..  **************
 206	2017-04-30 17:01	33  **************
 207	2017-04-30 17:02	34  ***************
 ...	..(  5 skipped).	..  ***************
 213	2017-04-30 17:08	34  ***************
 214	2017-04-30 17:09	35  ****************
 ...	..( 26 skipped).	..  ****************
 241	2017-04-30 17:36	35  ****************
 242	2017-04-30 17:37	34  ***************
 312	2017-04-30 18:47	34  ***************
 313	2017-04-30 18:48	35  ****************
 ...	..(239 skipped).	..  ****************
  75	2017-04-30 22:48	35  ****************
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2			5  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2			5  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4		 3425  Vendor specific
m0nkey_
Beside the fact you're using an insufficient amount of RAM, your drive is failing. Replace it.
joeschmuck
Old Man
As the others have stated, the RAM is low however your issue is all the failing sectors on the hard drive. You have 318 Reallocated sectors! You have potenitally another 30 failing sectors. The drive is dead. Were you running frequent SMART tests, it doesn't look like it? This would have notified you of the drive failures well before it got this bad.
I don't understand. Are you saying that ada0 and ada1 are for the mirror "Volume1" and that ada2 was a single stripe drive? If that is the case then you should try to import your failed drive (Google search it) however given all the sector errors of the drive, your data could very well be gone.
