Howdy folks,
Been running FreeNAS problem free for a year nearly, until earlier this week.
I started getting the below in daily email reports. Did a search, so I've tried different cables (3 now) and tried two different ports on the motherboard (supermicro x11ssh)
Also below is the SMART results, which look clean to me. I have a spare drive I can pop in and run the resilver, but am I missing anything obvious, before trying that?
Z2 pool consisting of 6x3TB wd reds
Xeon E3-1240 v5
X11SSH
32GB EEC Samsung RAM (straight off the QVL)
Seasonic X850
(Using onboard sata ports, but do have a couple of HBA's here if needed.)
Thanks in advance.
Xeon E3-1240 v5
X11SSH
Seasonic X850
Thanks in advance.
Jan 4 17:41:50 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 d8 dc 98 40 fd 00 00 00 00 00 Jan 4 17:41:50 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 17:41:50 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 17:41:50 freenas (ada1:ahcich2:0:0:0): RES: 41 10 d8 dc 98 40 fd 00 00 00 00 Jan 4 17:41:50 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 17:41:57 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 18 20 1a 05 40 83 00 00 00 00 00 Jan 4 17:41:57 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 17:41:57 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 17:41:57 freenas (ada1:ahcich2:0:0:0): RES: 41 10 20 1a 05 40 83 00 00 00 00 Jan 4 17:41:57 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 18:55:50 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 70 00 42 40 20 00 00 00 00 00 Jan 4 18:55:50 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 18:55:50 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 18:55:50 freenas (ada1:ahcich2:0:0:0): RES: 41 10 70 00 42 40 20 00 00 00 00 Jan 4 18:55:50 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 18:55:57 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 18 18 9e a2 40 fd 00 00 00 00 00 Jan 4 18:55:57 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 18:55:57 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 18:55:57 freenas (ada1:ahcich2:0:0:0): RES: 41 10 18 9e a2 40 fd 00 00 00 00 Jan 4 18:55:57 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 21:19:00 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 38 ca 1e 40 fb 00 00 00 00 00 Jan 4 21:19:00 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 21:19:00 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 21:19:00 freenas (ada1:ahcich2:0:0:0): RES: 41 10 38 ca 1e 40 fb 00 00 00 00 Jan 4 21:19:00 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 21:43:15 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 10 df 24 40 fb 00 00 01 00 00 Jan 4 21:43:15 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 21:43:15 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 21:43:15 freenas (ada1:ahcich2:0:0:0): RES: 41 10 10 df 24 40 fb 00 00 00 00 Jan 4 21:43:15 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 21:45:24 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 b8 01 40 40 00 00 00 00 00 00 Jan 4 21:45:24 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 21:45:24 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 21:45:24 freenas (ada1:ahcich2:0:0:0): RES: 41 10 b8 01 40 40 00 00 00 00 00 Jan 4 21:45:24 freenas (ada1:ahcich2:0:0:0): Retrying command Jan 4 21:45:31 freenas (ada1:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 48 80 25 40 fb 00 00 00 00 00 Jan 4 21:45:31 freenas (ada1:ahcich2:0:0:0): CAM status: ATA Status Error Jan 4 21:45:31 freenas (ada1:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Jan 4 21:45:31 freenas (ada1:ahcich2:0:0:0): RES: 41 10 48 80 25 40 fb 00 00 00 00 Jan 4 21:45:31 freenas (ada1:ahcich2:0:0:0): Retrying command
[root@freenas] ~# smartctl -a /dev/ada1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WCC4N5VPZL04 LU WWN Device Id: 5 0014ee 26204ddaf Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Jan 6 13:53:22 2017 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (39360) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 395) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 176 176 021 Pre-fail Always - 6166 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 19 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 7573 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 19 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 8 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 136 194 Temperature_Celsius 0x0022 135 117 000 Old_age Always - 15 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 7537 - # 2 Short offline Completed without error 00% 7301 - # 3 Extended offline Completed without error 00% 7213 - # 4 Short offline Completed without error 00% 7133 - # 5 Short offline Completed without error 00% 6965 - # 6 Extended offline Completed without error 00% 6878 - # 7 Short offline Completed without error 00% 6797 - # 8 Short offline Completed without error 00% 6581 - # 9 Extended offline Completed without error 00% 6494 - #10 Short offline Completed without error 00% 6413 - #11 Short offline Completed without error 00% 6246 - #12 Extended offline Completed without error 00% 6160 - #13 Short offline Completed without error 00% 6079 - #14 Short offline Completed without error 00% 5838 - #15 Extended offline Completed without error 00% 5751 - #16 Short offline Completed without error 00% 5671 - #17 Short offline Completed without error 00% 5503 - #18 Extended offline Completed without error 00% 5415 - #19 Short offline Completed without error 00% 5335 - #20 Short offline Completed without error 00% 5119 - #21 Extended offline Completed without error 00% 5031 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
