My current (6.5 year old) FreeNAS box has a supermicro board with IPMI which I like and rely on at times. However, the board seems to be dead, so it's time for a new build (all other components are old except drives which are 2ish years old).
Current State: I currently use my FreeNAS box to host videos and photos for the family with some music and few movies. It also does PC & Mac backup duty. Finally, it is storage for a ESXi Server.
Desired State: Essentially the same. However, I may dive into Plex, so I don't know about transcoding options and needs if I do something like that. Essentially, I may want room to grow from a processor standpoint. So if a XEON is $50 more than an I3, I'd probably go that route to leave doors open. If it's $200 more, I probably wouldn't.
I've been browsing this forum for information and there's a ton, which is awesome! On this thread (https://forums.freenas.org/index.php?threads/need-your-approval-for-a-freenas-project.68940/) Chris Moore suggested this machine (http://www.tigerdirect.com/applicat...urce=cj&utm_content=8192570&utm_term=12861979) as a prebuilt option. In the past, HP servers required an iLO license, is that still the case, or is remote management included in this board. If so, what RAM is the current recommendation for this machine (want 16 GB)?
$285 (server) + $200 (RAM) = $485 + drives + anything else needed??
If I don't go that route, I'd probably go with the following self built setup:
Fractal R5 ($80-100): https://www.ebay.com/itm/173352521681
Supermicro MBD-X11SSM-F-O ($200): https://www.newegg.com/Product/Product.aspx?Item=N82E16813183013
Intel Xeon E3-1220 V6 Kaby Lake ($210): https://www.newegg.com/Product/Product.aspx?item=N82E16819117790
16 GB ECC RAM (~$200)
Good PSU (~$70) from recommendations on this site (Seasonic I think is what I'm seeing recommended)
$80 + $200 + $210 + $200 + $70 = $860
As much as I like building machines, the HP looks like it's about $380 less. I know the self built has a Xeon, but the I3 I found looks like it's only about $40 less. And if I cut the MOBO and CPU in half, it'd still be $200 more than the HP. And I couldn't find a cheaper MOBO option from the suggested hardware list.
So, actual questions I need help with
1. Does the HP have remote console (like IPMI) so I don't need a keyboard/mouse/monitor hooked up and if so, does it require a separate license?
2. What RAM does is suggested?
3. Will it work well to serve files and iSCSI targets for an ESXi host?
Thank you!!!
Thank you!!!
