kirkdickinson
 - Jun 29, 2015
I keep lurking here and have the funds to pull the trigger and order stuff for a build.  I keep going back and forth. I need to replace an old WinXP server that has a RAID 6 with only 2.2 TB of storage. (5 750 Gig drives)
I also have 2TB of Video stuff that just keep on a main drive in my workstation and have an a B and a C drive that I manually mirror that to. Starting requirements at a bare minimum have to be 4TB just to copy what I have. I don't like to do anything on computers unless I double it, so I am thinking I need 8TB or more.
Am thinking about running a 4TB x 6 drive in Z3 for about 8.5 usable space. (using this calculator: https://jsfiddle.net/Biduleohm/hfqdpbLm/10/embedded/result/) I won't be filling this up anytime soon, so I can just rotate a couple 6TB drives in and out of a hot-swap bay to backup the array.
Here is what I have in my NewEgg Wishlist right now:
6 - WD Red WD40EFRX 4TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" NAS Internal Hard Drive - B
Capacity: 4TBPACKAGE: N/AStyle: N/A
Model #:WD40EFRX
Item #:9SIA2W01A21484
$178.95 $1,073.70
iStarUSA D400L7-DE8BK Steel 4U Rackmount High Performance Quiet Server Chassis
Model #:D400L7-DE8BK
Item #:N82E16811165389
$375.99
SUPERMICRO MBD-X10SL7-F-O Micro ATX Server Motherboard LGA 1150 Intel C222 DDR3 1600
Model #:MBD-X10SL7-F-O
Item #:N82E16813182821
$249.99
SUPERMICRO SSD-DM032-PHI SATA DOM (SuperDOM) Solutions
Model #:SSD-DM032-PHI
Item #:N82E16816139090
$69.99
SeaSonic S12G-450 450W ATX12V / EPS12V 80 PLUS GOLD Certified Active PFC Power Supply, Intel Haswell Ready
Model #:S12G-450
Item #:N82E16817151139
$69.99
Intel Xeon E3-1231V3 Haswell 3.4 GHz LGA 1150 80W BX80646E31231V3 Server Processor
Model #:BX80646E31231V3
Item #:N82E16819117316
$254.99
4 - Crucial 8GB 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600 (PC3 12800) Server Memory Model CT102472BA160B
Model #:CT102472BA160B
Item #:N82E16820191593
$62.99 $251.96
Total: $2,346.61
Model #:WD40EFRX
$178.95 $1,073.70
$375.99
$249.99
$69.99
Model #:S12G-450
$69.99
$254.99
$62.99 $251.96
Total: $2,346.61
