Please review my upcoming Build (Suggestions welcomed)
Purpose: FreeNAS Media Server on a ZF2 raid for 24TB usable (Plex Server) with my Chromebox (client) using Kodi player w/ Plex plugin.
Case: Fractal Design Define R4 - $69.99 @ Newegg
Power: SeaSonic S12G S12G-650 650W ATX12V / EPS12V 80 PLUS GOLD Certified Active PFC Power Supply - $84.99 @ Newegg
Motherboard: ASRock E3C224-4L ATX Server Motherboard LGA 1150 Intel C224 DDR3 1600/1333 - $198.99 @ Newegg
CPU: Intel Xeon E3-1231V3 Haswell 3.4 GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1150 80W BX80646E31231V3 Server Processor - $254.99 @ Newegg
Memory: Kingston 32GB (4 x 8GB) 240-Pin DDR3 SDRAM ECC Registered DDR3 1600 (PC3 12800) Server Memory Model KVR16R11S4K4/32I - $255.99 @ Amazon
HDD1: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive $249.99 @ Amazon
HDD2: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive $249.99 @ Amazon
HDD3: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive $249.99 @ Amazon
HDD4: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive $249.99 @ Amazon
HDD5: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive $249.99 @ Amazon
HDD6: Western Digital Red 6TB 3.5" 5400RPM Internal Hard Drive $249.99 @ Amazon
O/S: FreeNAS run from a Flash Drive
GRAND TOTAL: $2364.89
Am I overlooking anything or forgetting anything vital?
Sakuru
tvsjr
Upgrade the power supply - SeaSonic being the usual choice.
Why not run one of the highly-recommended Supermicro MBs rather than the Asrock?
Finally, keep in mind that this build will not give you 24TB usable. Per the calculator (https://jsfiddle.net/Biduleohm/hfqdpbLm/10/embedded/result/), accounting for overhead and the 80% rule, you're looking at 17.18TiB.
ChriZ
Not 100% sure, but E3 Xeons don't support registered RAM...
You need unbuffered DIMMs.
Fuganater
Also do not use Kingston RAM.
I also will say to go with a Supermicro board instead.
