rvassar
- May 2, 2018
I've collected enough pieces to start build #3, and hopefully escape from the howling fans and 120+ watt CPU's of 2008... I have a nice little Supermicro X9SCL, and the i3-2120 from build #2 (upgradable later to a Xeon E3-12xx). I picked up an inexpensive Cooler Master HAF 912 mid-tower case, which should give me room for ~9 x 3.5 drives, and a couple SSD's. The hangup at the moment is RAM. I'm one of those ham radio "junk box" types. I collect and keep all manner of electronic things that might be needed in the future. RAM is one of those things I try to meticulously strip from anything that's heading for the recycle bin, but I've only got 7 sticks of DDR3 ECC UDIMM's, and they're only 2Gb each. Motherboard only takes 4 x DIMM's, so I'm right at the 8Gb minimum for testing & burn-in.
My workload is almost exclusively NFS, with a small CIFS component, and I run Plex in the usual jail. I have two small Linux VM's configured, but they can go live elsewhere until I can get more RAM. My question: How much RAM does Plex need? Is there any headroom for it in the 8Gb mandatory minimum, or should I be patient and put up with the howling fans of the SC1430 until next payday? :)
