FreeNAS for Plex dream build...
Ender117
I would like to chime in that if you want to transcode 4k you might want a separate plex box with hardware transcode capability. Something like lastest coffelake with a decent iGPU. Transcoding 4k is very CPU intensive, I have tried this on a dual E5 2690v2 system and could barely do 2 4k streams, and it was no way quiet when it was doing that.
It is just inefficient to get more CPU power to transcode 4k, and GPU have almost no use in FreeNAS, as others pointed out. So my suggestion to build dedicated plex box with consumer hardware.
Chris Moore
I would like to chime in that if you want to transcode 4k you might want a separate plex box with hardware transcode capability. Something like lasted coffelake with a decent iGPU. Transcoding 4k is very CPU intensive, I have tried this on a dual E5 2690v2 system and could barely do 2 4k streams, and it was no way quiet when it was doing that.
I will keep saying this until people stop asking:
https://www.cnet.com/news/why-ultra-hd-4k-tvs-are-still-stupid/
Also:
https://www.forbes.com/sites/kevinm...look-the-emperor-has-no-clothes/#47b81f2deaa5
Ender117
CodeBeing
So here's where my research has landed me on hardware, based on this forum's hardware guide and my own, insane need to buy new. Thoughts / Comments / Feedback welcome:
~$2700 total. Am I missing anything?
Motherboard: $213
Supermicro Micro ATX DDR4 LGA 1151 Motherboards X11SSM-F-O
https://www.newegg.com/Product/Prod...M8969&cm_re=X11SSM-F-O-_-13-183-013-_-Product
Processor: $269.99
Intel Xeon E3-1230 V6
https://www.newegg.com/Product/Prod...=Intel_Xeon_E3-1230_V6-_-19-117-788-_-Product
Promo code INLA23V6P - $260
CPU Cooler: $120
Corsair Hydro Series H100i PRO Low Noise 240mm RGB Water/Liquid CPU Cooler
https://www.newegg.com/Product/Product.aspx?Item=N82E16835181141&ignorebbr=1
PSU: $80 after $30 rebate
Seasonic FOCUS Plus Series SSR-650PX 650W 80+ Platinum ATX12V & EPS12V Full Modular 120mm FDB Fan 10 Years Warranty Compact 140 mm Size Power Supply
https://www.newegg.com/Product/Product.aspx?item=N82E16817151192
Memory: $370
32GB ECC DDR4 2400
Crucial
https://www.newegg.com/Product/Prod...DDR4_2400_ECC_32GB-_-0RM-0037-00008-_-Product
Case: $106
https://www.newegg.com/Product/Prod...cm_re=fractal_node_804-_-11-352-047-_-Product
Fractal Node 804
Fans: $55.60
Noctua 120mm fans x 4
https://www.newegg.com/Product/Product.aspx?Item=9SIAADY76G1796&ignorebbr=1
UPS: $271
https://www.newegg.com/Product/Prod..._re=APC_Smart_Ups_1000-_-42-301-544-_-Product
APC SMC1000C 1000 VA 600 Watts
Drives: $1,109.94
WD Red 6TB - 6 drives total
https://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3608314
Boot Drive: $88
Samsung 860 EVO
https://www.newegg.com/Product/Product.aspx?Item=N82E16820147674&ignorebbr=1
Chris Moore
I would suggest that you don't need the water cooler ... it's just one more thing to break. Simple airflow cooling is best.
Chris Moore
Thanks Chris! Anything else look insane otherwise?
I wouldn't say insane. If you just gotta have new hardware, and you have the money, you could buy one for me while you are at it...
Seriously, it looks like a good set of hardware. I am personally not a fan of the Western Digital hard drives because I don't like the way they report the SMART data. If I were buying, I would buy Seagate, despite my recent bad experience with a particular model they are selling that uses SMR (Shingled Magnetic Recording) to cram more data on the drive through a hardware compression scheme.
Those Western Digital drives, even with the 'combo' price are about $184 each and for that money, I would go with these instead:
Seagate IronWolf 6TB NAS Hard Drive 7200 RPM 128MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive ST6000VN0041
https://www.newegg.com/Product/Product.aspx?item=N82E16822179004
Chris Moore
I don't know if you have seen this, but I have shared it, or very similar all over the forum. This build of used gear is only about $650 ish, not counting drives, which I would still get new, but it would save you a lot of cash and still be very capable:
You might want to look, just for kicks:
Some assembly required...
CASE: Fractal-Design-Define-R5-FD-CA-DEF-R5-BK-Black-Silent-ATX-Midtower-Computer-Case - - US $104.99
https://www.ebay.com/itm/253026336681
These are older components, but still very powerful.
I use similar components in both my 48 bay primary NAS and in my 24 bay backup NAS that runs ESXi with FreeNAS in a VM.
This one comes with a CPU and fan and 32GB of memory, but it is really slow CPU, so probably want to replace that:
System Board: SuperMicro X9SRL-F AXT Motherboard w/ I/O, 32GB RAM Intel Xeon E5-2603 1.80GHz - - US $179.99 plus shipping $28.32
https://www.ebay.com/itm/401606434468
Nothing included with this one, so the price is lower, but an option:
Supermicro X9SRL-F Motherboard Socket LGA2011 System Board w/ I/O Shield - - US $189.98
https://www.ebay.com/itm/113216257183
If you want more memory, this board can take 128 GB of these 16GB sticks, if I recall correctly:
Memory: SAMSUNG 16GB PC3L-12800R DDR3-1600 ECC Registered 1.35V RDIMM - - US $44.95
https://www.ebay.com/itm/302606459277
Note: You could go for the 32GB memory modules, but they are more than twice the price.
If the board above doesn't come with a cooler, or you want a better one, I use this model on two of my systems.
It is only slightly louder than the Noctua cooler I have on my wife's desktop PC.
CPU Fan: Dynatron R27 Side Fan CPU Cooler 3U for Intel Socket LGA2011 (Narrow ILM) - - US $39.59
https://www.ebay.com/itm/401284811045
The CPU that comes in the board above is pretty low speed, so you might find that you need a better one.
You have a lot of options for CPUs to go in this board, but I recently bought one of these for myself:
PassMark score of 13073... If you are wondering... This is the model I use for the NAS I run Plex in.
CPU: Intel Xeon E5-2650 V2 2.6GHz 8 Core 20MB 8GT/s SR1A8 LGA2011 ( Ivy Bridge ) Processor - - US $89.97
https://www.ebay.com/itm/142937685210
Only it was $30 more when I bought it... It works great. Plenty of resources for all the things I am doing.
If you want more, you can get a 10 core model like this:
Intel Xeon E5-2680 v2 Ten Core 2.8GHz 25MB CPU PROCESSOR LGA2011 SR1A6 - - Price: US $113.95
PassMark score of 15796... If you are wondering...
https://www.ebay.com/itm/142954574638
For the drive controller, I would suggest a SAS controller, just to get all the drives on a single controller. It works better that way. One SAS controller like this can run up to 256 drives by use of expander controllers. We can talk more about that when you need more drives but this will get you to eight drives to start.
Drive Controller: SAS PCI-E 3.0 HBA LSI 9207-8i P20 IT Mode for ZFS FreeNAS unRAID - - US $69.55
https://www.ebay.com/itm/162862201664
Drive Cables: Mini SAS to 4-SATA SFF-8087 Multi-Lane Forward Breakout Internal Cable - - US $12.99
https://www.ebay.com/itm/371681252206
I would suggest one of these SSDs for the boot drive.
These are used data-center drives, but as a boot drive in FreeNAS, it should last as long as the server, if not longer:
Boot drive: 120GB Intel SSD DC S3500 Series HP Model: TK0120GDJXT SSDSC2BB120G4B SATA 6Gb/s - - Approximately US $38.68
https://www.ebay.com/itm/323462963823
Thermal Compound: Noctua NT-H1 Thermal Paste Grease Conductive Compound for CPU/GPU - US $6.95
https://www.ebay.com/itm/302624513215
Just rough math in my head, I think that is all around $650.... Still, you might need some odd bits, and hard drives, but it should be simple to get there from here and this should save you a buck or two vs buying new and still do the job for years to come.
Ender117
Motherboard: $213
Processor: $269.99
CPU Cooler: $120
Memory: $370
32GB ECC DDR4 2400
Crucial
Case: $106
Fractal Node 804
Fans: $55.60
UPS: $271
Drives: $1,109.94
Boot Drive: $88
Samsung 860 EVO
I just want to add that you don't need 500gb for a boot disk, unless of course you are planning to run a dozen of jails/vm......
Chris Moore
The boot pool can't be used for anything besides the boot data and you can keep your system dataset there. Having a large one serves no purpose at all. I usually suggest the smallest SSD you can find, used, and I am running a mirrored pair of 40 GB actual hard drives that were intended for laptop use. No problems at all for over two years.
Ender117
Oh I was under the impression that jail dataset can be on the boot pool. Then yes, a tiny SSD should be enough.
I would recommend a 80G s3500 from ebay, you can usually get them as used for ~25. I got a bunch of those and they still have 95%+ write endurance when arrived. You probably will never use up that limit...
Chris Moore
Normally that is true, and I suggest that very type, but they appear to be out of them right now. The alternatives that eBay suggests are not priced competitively.
Ender117
Looks like that way. Then a intel 320 for less than 20 is 2nd on my list. Really any SSD would do I believe. I would avoid HDD though unless you have some laying around
rmccullough
Not sure where this ended up, but it may be better to split these systems. Build 1 for FreeNAS with slower CPU, and a 2nd system for hosting Plex and doing transcoding that has fewer cores running at a higher clock speed.
pro lamer
MorkaiTheWolf
If a separate rig then just go for a GPU based transcoding...
Sent from my mobile phone
Does plex really benefit all that much from GPU based transcoding? Last I read it wasn't super stable and you still see more bang for your buck with a more powerful CPU vs a more powerful GPU.
Not to mention plex transcoding is multithreaded so more cores tend to help.
pro lamer
I didn't know, thanks. I am not experienced in this field.
To be more precise: my colleagues transcode some 4K H.265 using CPUs plus GPU. They decode a stream using 60% of cores of two e5-2690v2 Xeons and then encode it into two streams using 60% of some decent GPU.
So I thought GPU was kind of future proof.
Now some wild guess: maybe some kind of Intel quick sync or it's newer version would be enough... or some CPU with AVX-512...? No idea, just guessing...
