Bug, I think: Check 'freenas_health' is now warning after moving disks around (?)
devnullius
devnullius
I rebooted once: all hdd leds are done blinking.
These are from the dmesg output:
uhub7: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
mps0: SAS Address for SATA device = 1a0717249b6e673d
mps0: SAS Address for SATA device = d264403bd9c9bc76
mps0: SAS Address for SATA device = 1e181e249b6e673c
mps0: SAS Address for SATA device = d2644137dec7be76
mps0: SAS Address for SATA device = 25083b249b6e6739
mps0: SAS Address for SATA device = 122638249b6e643e
mps0: SAS Address for SATA device = 1e1f19249b6e673c
mps0: SAS Address for SATA device = d2666346ecdbb96e
mps0: SAS Address from SATA device = 1a0717249b6e673d
mps0: SAS Address from SATA device = d264403bd9c9bc76
mps0: SAS Address from SATA device = 1e181e249b6e673c
mps0: SAS Address from SATA device = d2644137dec7be76
mps0: SAS Address from SATA device = 25083b249b6e6739
mps0: SAS Address from SATA device = 122638249b6e643e
mps0: SAS Address from SATA device = 1e1f19249b6e673c
mps0: SAS Address from SATA device = d2666346ecdbb96e
uhub0: 2 ports with 2 removable, self
da0 at mps0 bus 0 scbus1 target 0 lun 0
da2 at mps0 bus 0 scbus1 target 2 lun 0
da0: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SPC-4 SCSI device
da0: Serial Number WD-WMC4N2081759
da3 at mps0 bus 0 scbus1 target 8 lun 0
da0: 600.000MB/s transfers
da0: Command Queueing enabled
da6 at mps0 bus 0 scbus1 target 11 lun 0
da0: 2861588MB (5860533168 512 byte sectors)
da3: <ATA MB3000EBUCH HPG0> Fixed Direct Access SPC-4 SCSI device
da3: Serial Number YHKLJ61A
da3: 300.000MB/s transfers
da3: Command Queueing enabled
da0: quirks=0x8<4K>
da2: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SPC-4 SCSI device
da2: Serial Number WD-WMC4N2146579
da2: 600.000MB/s transfers
da2: Command Queueing enabled
da2: 2861588MB (5860533168 512 byte sectors)
da2: quirks=0x8<4K>
da5 at mps0 bus 0 scbus1 target 10 lun 0
da8 at umass-sim0 bus 0 scbus10 target 0 lun 0
da6: da3: 2861588MB (5860533168 512 byte sectors)
da8: da6: Serial Number YHKKNG8A
da6: 300.000MB/s transfers
da6: Command Queueing enabled
da6: 2861588MB (5860533168 512 byte sectors)
da5: <ATA MB3000EBUCH HPG3> Fixed Direct Access SPC-4 SCSI device
da5: Serial Number YHHMBURA
da5: 300.000MB/s transfers
da5: Command Queueing enabled
da5: 2861588MB (5860533168 512 byte sectors)
< USB DISK 2.0 PMAP> Removable Direct Access SPC-2 SCSI device
da8: Serial Number 0701C20F654FCCE5
da8: 40.000MB/s transfers
da8: 15272MB (31277056 512 byte sectors)
da8: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
da4 at mps0 bus 0 scbus1 target 9 lun 0
da4: <ATA MB3000EBUCH HPG0> Fixed Direct Access SPC-4 SCSI device
da4: Serial Number YHKHU7UA
da4: 300.000MB/s transfers
da4: Command Queueing enabled
da4: 2861588MB (5860533168 512 byte sectors)
da1 at mps0 bus 0 scbus1 target 1 lun 0
da1: <ATA WDC WD30EFRX-68E 0A82> Fixed Direct Access SPC-4 SCSI device
da1: Serial Number WD-WCC4N4SCDS21
da1: 600.000MB/s transfers
da1: Command Queueing enabled
da1: 2861588MB (5860533168 512 byte sectors)
da1: quirks=0x8<4K>
ada0 at ahcich1 bus 0 scbus4 target 0 lun 0
ada0: <ST3500418AS CC3E> ATA8-ACS SATA 2.x device
ada0: Serial Number 5VM9WHZY
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 476940MB (976773168 512 byte sectors)
cd0 at ahcich4 bus 0 scbus7 target 0 lun 0
ada1 at ahcich3 bus 0 scbus6 target 0 lun 0
cd0: <PLEXTOR DVDR   PX-880SA 1.12> Removable CD-ROM SCSI device
cd0: Serial Number 3743524162 337020504
cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytesada1: <WDC WD101KRYZ-01JPDB1 01.01H02> ACS-2 ATA SATA 3.x d
evice
ada1: Serial Number 7JK6PLTC
ada1: 300.000MB/s transfers)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
ada1: Command Queueing enabled
ada1: 9537536MB (19532873728 512 byte sectors)
da7 at mps0 bus 0 scbus1 target 12 lun 0
da7: <ATA MB3000EBUCH HPG0> Fixed Direct Access SPC-4 SCSI device
da7: Serial Number YHKKNN3A
da7: 300.000MB/s transfers
da7: Command Queueing enabled
da7: 2861588MB (5860533168 512 byte sectors)
random: unblocking device.
Trying to mount root from zfs:freenas-boot/ROOT/default
da1: quirks=0x8<4K>
evice
Trying to mount root from zfs:freenas-boot/ROOT/default []...
em1: link state changed to UP
ipmi0: <IPMI System Interface> on isa0
ipmi0: KCS mode found at io 0xca2 alignment 0x1 on isa
ipmi0: couldn't find it
device_attach: ipmi0 attach returned 6
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67
<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
em1: link state changed to DOWN
I hope I didn't miss anything here - the Shell worked kind'a funny with Edge (and not all with IE).
devnullius
I started a full wipe of da0 once again after a reboot. After the reboot all HDD leds were off - as it should.
BUT when I started the wipe, da5 HDD led started to burn constantly again - I don't see any HDD led activity on da0 either. It's almost as if FreeNAS is confused after I moved some disks around. I don't see a reason why it should be? Is this a bug? Should I start with a fresh FreeNAS installation? I'll tree to read this when I am home again https://forums.freenas.org/index.ph...with-11-1-rc1-and-now-11-1-11-1-u1-too.58844/.
devnullius
I've only noticed just now (sigh)... The GUI doesn't reflect me moving some disks around.
da0 still has the Serial of the previous disk. I moved 3 disks around... I bet those were the disks I couldn't quick wipe previously. And why the leds are misbehaving. And why my Full Wipe of da0 (now at 14%) is going to fail any minute now...
I'll do a fresh install when I'm home again.
Post-edit: the subject now should read: FreeNAS 11 GUI: disk Serial not updated / incorrect / wrong after moving disks around?
devnullius
Fresh install, I can now create a pool with the 8 disks. I still don't think the Serials match so that must mean I'm wrong here. I'll double check that later.
BUT...
Console:
freenas smartd: Unable to register device /dev/da8 (no Directive -d removable). Exiting.
UPDATE: my bad, that's the USB drive (da8).
BUT :)
Whaaat?
Feb  3 06:02:02 freenas daemon[5900]: BootstrapExpect is set to 1; this is the same as Bootstrap mode.
Feb  3 06:02:02 freenas daemon[5900]: bootstrap = true: do not enable unless necessary
Feb  3 06:02:02 freenas daemon[5900]: ==> Starting Consul agent...
Feb  3 06:02:02 freenas daemon[5900]: ==> Consul agent running!
Feb  3 06:02:02 freenas daemon[5900]:			Version: 'v1.0.0'
Feb  3 06:02:02 freenas daemon[5900]:			Node ID: '07c79ab5-557b-b4df-49a3-67aedd99bf3f'
Feb  3 06:02:02 freenas daemon[5900]:		  Node name: 'freenas.local'
Feb  3 06:02:02 freenas daemon[5900]:		 Datacenter: 'dc1' (Segment: '<all>')
Feb  3 06:02:02 freenas daemon[5900]:			 Server: true (Bootstrap: true)
Feb  3 06:02:02 freenas daemon[5900]:		Client Addr: [127.0.0.1] (HTTP: 8500, HTTPS: -1, DNS: 8600)
Feb  3 06:02:02 freenas daemon[5900]:	   Cluster Addr: 127.0.0.1 (LAN: 8301, WAN: 8302)
Feb  3 06:02:02 freenas daemon[5900]:			Encrypt: Gossip: false, TLS-Outgoing: false, TLS-Incoming: false
Feb  3 06:02:02 freenas daemon[5900]: ==> Log data will now stream in as it occurs:
Feb  3 06:02:09 freenas daemon[5900]:	 2018/02/03 06:02:09 [ERR] agent: failed to sync remote state: No cluster leader
Feb  3 06:02:11 freenas daemon[5900]:	 2018/02/03 06:02:11 [WARN] raft: Heartbeat timeout from "" reached, starting election
Feb  3 06:02:28 freenas daemon[5900]:	 2018/02/03 06:02:28 [WARN] agent: Check 'freenas_health' is now warning
Feb  3 06:04:28 freenas daemon[5900]:	 2018/02/03 06:04:28 [WARN] agent: Check 'freenas_health' is now warning
Feb  3 06:06:24 freenas ZFS: vdev state changed, pool_guid=16365684983299924960 vdev_guid=6974793590789398571
Feb  3 06:06:29 freenas daemon[5900]:	 2018/02/03 06:06:29 [WARN] agent: Check 'freenas_health' is now warning
Feb  3 06:06:31 freenas ntpd[5042]: ntpd exiting on signal 15 (Terminated)
Feb  3 15:06:31 freenas ntpd[8292]: ntpd 4.2.8p10-a (1): Starting
Feb  3 06:06:34 freenas syslog-ng[4643]: syslog-ng shutting down; version='3.7.3'
Feb  3 15:06:35 freenas syslog-ng[8672]: syslog-ng starting up; version='3.7.3'
Feb  3 15:06:43 freenas ntpd[8293]: ntpd exiting on signal 15 (Terminated)
Feb  3 15:06:44 freenas ntpd[9023]: ntpd 4.2.8p10-a (1): Starting
Feb  3 06:07:40 freenas notifier: 32+0 records in
Feb  3 06:07:40 freenas notifier: 32+0 records out
Feb  3 06:07:40 freenas notifier: 33554432 bytes transferred in 0.254940 secs (131616929 bytes/sec)
Feb  3 06:07:41 freenas notifier: dd: /dev/da0: short write on character device
Feb  3 06:07:41 freenas notifier: dd: /dev/da0: end of device
Feb  3 06:07:41 freenas notifier: 33+0 records in
Feb  3 06:07:41 freenas notifier: 32+1 records out
Feb  3 06:07:41 freenas notifier: 34037760 bytes transferred in 0.523674 secs (64998023 bytes/sec)
Feb  3 06:07:42 freenas notifier: 32+0 records in
Feb  3 06:07:42 freenas notifier: 32+0 records out
Feb  3 06:07:42 freenas notifier: 33554432 bytes transferred in 0.269831 secs (124353394 bytes/sec)
Feb  3 06:07:42 freenas notifier: dd: /dev/da1: short write on character device
Feb  3 06:07:42 freenas notifier: dd: /dev/da1: end of device
Feb  3 06:07:42 freenas notifier: 33+0 records in
Feb  3 06:07:42 freenas notifier: 32+1 records out
Feb  3 06:07:42 freenas notifier: 34037760 bytes transferred in 0.497112 secs (68470994 bytes/sec)
Feb  3 06:07:43 freenas notifier: 32+0 records in
Feb  3 06:07:43 freenas notifier: 32+0 records out
Feb  3 06:07:43 freenas notifier: 33554432 bytes transferred in 0.279658 secs (119983920 bytes/sec)
Feb  3 06:07:44 freenas notifier: dd: /dev/da2: short write on character device
Feb  3 06:07:44 freenas notifier: dd: /dev/da2: end of device
Feb  3 06:07:44 freenas notifier: 33+0 records in
Feb  3 06:07:44 freenas notifier: 32+1 records out
Feb  3 06:07:44 freenas notifier: 34037760 bytes transferred in 0.551501 secs (61718423 bytes/sec)
Feb  3 06:07:45 freenas notifier: 32+0 records in
Feb  3 06:07:45 freenas notifier: 32+0 records out
Feb  3 06:07:45 freenas notifier: 33554432 bytes transferred in 0.754606 secs (44466153 bytes/sec)
Feb  3 06:07:46 freenas notifier: dd: /dev/da3: short write on character device
Feb  3 06:07:46 freenas notifier: dd: /dev/da3: end of device
Feb  3 06:07:46 freenas notifier: 33+0 records in
Feb  3 06:07:46 freenas notifier: 32+1 records out
Feb  3 06:07:46 freenas notifier: 34037760 bytes transferred in 0.338919 secs (100430400 bytes/sec)
Feb  3 06:07:50 freenas notifier: 32+0 records in
Feb  3 06:07:50 freenas notifier: 32+0 records out
Feb  3 06:07:50 freenas notifier: 33554432 bytes transferred in 0.653735 secs (51327290 bytes/sec)
Feb  3 06:07:50 freenas notifier: dd: /dev/da4: short write on character device
Feb  3 06:07:50 freenas notifier: dd: /dev/da4: end of device
Feb  3 06:07:50 freenas notifier: 33+0 records in
Feb  3 06:07:50 freenas notifier: 32+1 records out
Feb  3 06:07:50 freenas notifier: 34037760 bytes transferred in 0.317506 secs (107203421 bytes/sec)
Feb  3 06:07:54 freenas notifier: 32+0 records in
Feb  3 06:07:54 freenas notifier: 32+0 records out
Feb  3 06:07:54 freenas notifier: 33554432 bytes transferred in 0.739972 secs (45345523 bytes/sec)
Feb  3 06:07:55 freenas notifier: dd: /dev/da5: short write on character device
Feb  3 06:07:55 freenas notifier: dd: /dev/da5: end of device
Feb  3 06:07:55 freenas notifier: 33+0 records in
Feb  3 06:07:55 freenas notifier: 32+1 records out
Feb  3 06:07:55 freenas notifier: 34037760 bytes transferred in 0.348217 secs (97748840 bytes/sec)
Feb  3 06:07:59 freenas notifier: 32+0 records in
Feb  3 06:07:59 freenas notifier: 32+0 records out
Feb  3 06:07:59 freenas notifier: 33554432 bytes transferred in 0.698779 secs (48018693 bytes/sec)
Feb  3 06:07:59 freenas notifier: dd: /dev/da6: short write on character device
Feb  3 06:07:59 freenas notifier: dd: /dev/da6: end of device
Feb  3 06:07:59 freenas notifier: 33+0 records in
Feb  3 06:07:59 freenas notifier: 32+1 records out
Feb  3 06:07:59 freenas notifier: 34037760 bytes transferred in 0.333659 secs (102013489 bytes/sec)
Feb  3 06:08:03 freenas notifier: 32+0 records in
Feb  3 06:08:03 freenas notifier: 32+0 records out
Feb  3 06:08:03 freenas notifier: 33554432 bytes transferred in 0.657571 secs (51027854 bytes/sec)
Feb  3 06:08:03 freenas notifier: dd: /dev/da7: short write on character device
Feb  3 06:08:03 freenas notifier: dd: /dev/da7: end of device
Feb  3 06:08:03 freenas notifier: 33+0 records in
Feb  3 06:08:03 freenas notifier: 32+1 records out
Feb  3 06:08:03 freenas notifier: 34037760 bytes transferred in 0.339993 secs (100112989 bytes/sec)
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=1393327519525484932
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=10072405200938199432
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=9137840257573747578
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=3403104535018527602
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=7298827713869855679
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=3285446550968059046
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=10199740117113071912
Feb  3 15:08:07 freenas ZFS: vdev state changed, pool_guid=10077381695198837077 vdev_guid=9220126904646551662
Feb  3 15:08:10 freenas GEOM_MIRROR: Device mirror/swap0 launched (2/2).
Feb  3 15:08:11 freenas GEOM_MIRROR: Device mirror/swap1 launched (2/2).
Feb  3 15:08:11 freenas GEOM_MIRROR: Device mirror/swap2 launched (2/2).
Feb  3 15:08:11 freenas GEOM_MIRROR: Device mirror/swap3 launched (2/2).
Feb  3 15:08:11 freenas GEOM_ELI: Device mirror/swap0.eli created.
Feb  3 15:08:11 freenas GEOM_ELI: Encryption: AES-XTS 128
Feb  3 15:08:11 freenas GEOM_ELI:	 Crypto: hardware
Feb  3 15:08:11 freenas GEOM_ELI: Device mirror/swap1.eli created.
Feb  3 15:08:11 freenas GEOM_ELI: Device mirror/swap2.eli created.
Feb  3 15:08:11 freenas GEOM_ELI: Device mirror/swap3.eli created.
Feb  3 15:08:19 freenas smartd[13190]: Device: /dev/ada0, WARNING: A firmware update for this drive may be available,
Feb  3 15:08:19 freenas smartd[13190]: see the following Seagate web pages:
Feb  3 15:08:19 freenas smartd[13190]: http://knowledge.seagate.com/articles/en_US/FAQ/207931en
Feb  3 15:08:19 freenas smartd[13190]: http://knowledge.seagate.com/articles/en_US/FAQ/213891en
Feb  3 15:08:19 freenas smartd[13190]: Unable to register device /dev/da8 (no Directive -d removable). Exiting.
Feb  3 06:08:29 freenas daemon[5900]:	 2018/02/03 06:08:29 [WARN] agent: Check 'freenas_health' is now warning
Feb  3 06:10:30 freenas daemon[5900]:	 2018/02/03 06:10:30 [WARN] agent: Check 'freenas_health' is now warning
Feb  3 06:12:30 freenas daemon[5900]:	 2018/02/03 06:12:30 [WARN] agent: Check 'freenas_health' is now warning
Feb  3 06:14:30 freenas daemon[5900]:	 2018/02/03 06:14:30 [WARN] agent: Check 'freenas_health' is now warning
--> this error remains: "[WARN] agent: Check 'freenas_health' is now warning"
joeschmuck
Old Man
You really should check the bug reports or at least use Google to search for "FreeNAS check freenas health warning" and find out that this has already been reported and scheulded to be fixed. This problem came to light in FreeNAS 11.1-U1.
devnullius
Thank you for the confirmation. If you ever figure it out do give a short reply here? If I find something I'll do the same.
joeschmuck
Old Man
If you read the bug report you will see that it is targeted to be fixed in FreeNAS 11.1-U2.
