Broken after upgrade
dannas
Being that this is the first post here it's unlikely the post will bee seen, much less receive a response.
I made the mistake of upgrading the Zoneminder plugin when I saw an update was ready. after the update the UI was blank, and error in the log said that there was no 'session' table. I did create the table, and was able to get some of the UI to work, which was useful for viewing the other errors. Am I alone here, or have other experienced this?
Like a dummy, I forgot to make a snapshot first.
Never again.
dannas
Looking through the logs, I did see an error about the DB version not matching the software version.
I opened a shell
I did a
sudo zmupdate.pl
The DB went through several updates. Success, back to normal.
I hope this helps someone.
Redcoat
Sorry to "disappoint" you.
Welcome to the forums!
Glad you were able to fix it.
I'll admit to having given up on Zoneminder a couple of years ago and never going back to it, so it's good to hear a +ve experience,
Thanks for reinforcing the snapshot. No question - it's a great facility to have.
When you are next here, please post your hardware specs to help others calibrate the application of your post's solution on Zoneminder.
