Broken UI after interface deletion
Analius
I just now deleted some left over network interfaces after uploading a config file.
This went fine, however the homepage of the UI still had widgets of these network interfaces. Because of this, the UI is now broken and keeps trying to load these. This results in none of the other buttons to function because of the javascript errors.
How do I fix this? Is there a way to "reset" the UI?
Samuel Tai
Analius
I can't do that because the reconfigure button doesn't work. None of the buttons that are controlled by javascript worked.
I ended up re-uploading the configurationfile and remove the widgets before removing the interfaces. So my problem is solved, but the underlying issue is not
Patrick M. Hausen
Are you referring to TrueNAS SCALE? Because as far as I know CORE does not have a way to customize the dashboard, yet. The code in SCALE is therefore rather new and might still have some problems. Please file a bug ticket in JIRA.
Thanks.
