Hello, I have a FreeNAS machine I installed about a year ago. The install is a VM with 2 LSI 9211s passthrough, 32 GB of DDR3 ECC RAM, and 4 vCores from dual x5660s. I have two arrays: ESXi and Storage. ESXi is working fine; It's a RaidZ of 4 256GB SSDs. Storage is the , now, problem child. It was originally 8 x 1TB drives in a RaidZ2. I added another 4 x 2TB drives later for space. About two months ago, things started to go sideways without me realizing. One drive failed. I got the email from FreeNAS, shut the system down, swapped the drive (a 1TB for a 2TB), started the system back up and clicked replace. It seemed to go ok and I continued with my life. Over the next month, I started getting a lot of weird errors around storage but no two seemed to be the same so it never clicked that the problem was FreeNAS and not the individual machines and the Read/Write speeds never declined. The errors were thing like my NVR complaining about disconnecting from the SMB share often (I though network issues since other VMs weren't complaining), my gaming VM downloading slowly (always a troubled VM), a sync machine disconnecting a bit (OwnCloud Sync tool has always been finicky), etc. About a month ago, I got an email from FreeNAS that another drive had failed; It was the one I had replaced a month prior. It didn't fail any way I had seen before; it failed from checksum errors. I though the drive was bad so I swapped another 2TB in and send the drive for RMA. The second drive had checksum errors immediately but FreeNAS didn't say the array was degraded so I left it. Another week later FreeNAS changed it's mind and marked the drive bad. I started thinking cables so I swapped the issue 2TB drive into 4 different bays. In each new bay, the issue drive got it's checksum errors and the other drive would be ok. I moved it to bays on different cables, SAS ports, and controllers. I started to think that it was because I swapped a 1TB drive for a 2TB so I put all the drives back in their original bays and swapped the issue drive for a new 1TB. The new 1TB got the same errors. I shut the host down and booted into Ubuntu to run extended SMART tests on all the drives. They all passed. When I booted back into FreeNAS, all the check sum errors were gone, array is healthy again, but every other machine is still having the weird issues. It's to a point now where I'm having trouble copying files off FreeNAS (my off site backup failed during this problem), Steam downloads are limited by the speed of FreeNAS not my 80Mbps Internet, etc. What do I do?
