Boot ZFS pool upgrade
albertredneck
I see this in my status reports:
########## ZPool status report for freenas-boot ##########
  pool: freenas-boot
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
    still be used, but some features are unavailable.
    the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:00:27 with 0 errors on Thu Dec 31 03:45:27 2020
    NAME          STATE     READ WRITE CKSUM
    freenas-boot  ONLINE       0     0     0
      nvd1p2      ONLINE       0     0     0
errors: No known data errors
But I found this post in the forums:
So I'd like to have some second opinions about the matter. Should I ignore the warning and just forget about upgrading the pool forever?
Chris Moore
The warning:
If you follow the warning from @Ericloewe and do not upgrade the boot pool, you would be safe.
The 'upgrade' is for feature flags, which the boot pool does not really need / use.
Chris Moore
Chris Moore
hello
you say @Chris Moore that and is a resonable point of view (with what @Ericloewe warning)
but IF want to reinvent wheel why not ??
Just for kicks, I did an upgrade on a boot pool. The system did not crash and burst into flames, but I have not rebooted yet.
I don't see a way to do it from the GUI, so I gave it the old zpool upgrade freenas-boot at the command line.
It didn't give me any errors.
The boot pool situation is more nuanced than it used to be. GRUB is stuck with a GPL reimplementation of ZFS from the early feature flag days and doesn't support most of them.
The FreeBSD bootloader is much closer to the main OS, I think even encryption support was being actively worked on.
Of course, if you do upgrade, you'll only really be faced with a problem next time you try to boot...
