I used the GUI to upgrade from 9.3 to 9.10. Things seemed to have gone OK, but after the reboot I did zpool status and it told me I should upgrade "freenas-boot" and my main data volume so I did. After it did the boot volume it told me that I should run "gpart bootcode -b /boot/pmbr -p /boot/gptzfsboot -i 1 ada1". I did that for da12 and da13 (my mirrored boot USB sticks).
After reboot I got a "bootloader not found" error and could only restore via mounting the 9.10 install ISO and doing an upgrade. Now I'm back and things are OK, but apparently the "freenas-boot" volume still needs to be upgraded. Any ideas on what I'm doing wrong so I can upgrade the boot zpool volume to support the new flags in 9.10? Is this something I should even do to the boot volume?
Additionally, "zpool get version" doesn't report the actual version for my boot volume or my main data volume. I never even looked before as I did a fresh install and fresh data volume setup on 9.3 so I don't know if that's normal. Thanks for any help.
[root@freenas] ~# zpool status pool: freenas-boot state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 da12p2 ONLINE 0 0 0 da13p2 ONLINE 0 0 0 errors: No known data errors
[root@freenas] ~# zpool get version freenas-boot NAME PROPERTY VALUE SOURCE freenas-boot version - default
[root@freenas] ~# zpool upgrade This system supports ZFS pool feature flags. All pools are formatted using feature flags. Some supported features are not enabled on the following pools. Once a feature is enabled the pool may become incompatible with software that does not support the feature. See zpool-features(7) for details. POOL FEATURE --------------- freenas-boot multi_vdev_crash_dump spacemap_histogram enabled_txg hole_birth extensible_dataset embedded_data bookmarks filesystem_limits large_blocks [root@freenas] ~#
