albertredneck
- Aug 27, 2019
I see this in my status reports:
But I found this post in the forums:
www.truenas.com
So I'd like to have some second opinions about the matter. Should I ignore the warning and just forget about upgrading the pool forever?
########## ZPool status report for freenas-boot ########## pool: freenas-boot state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(5) for details. scan: scrub repaired 0B in 00:00:27 with 0 errors on Thu Dec 31 03:45:27 2020 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 nvd1p2 ONLINE 0 0 0 errors: No known data errors
ZFS Pool Upgrade for the boot volume doesn't work
So in my messages this pops up: WARNING: Oct. 2, 2017, 10:20 p.m. - New feature flags are available for volume freenas-boot. Refer to the "Upgrading a ZFS Pool" section of the User Guide for instructions. I then go to the Volumes, select freenas-boot, it show's the upgrade button. I...
