- Jan 14, 2023
I started configuring the multi_report.sh script and upon first run I was greeted with a critical error message to my surprise.
My boot pool is apparently degraded.
Hardware:
During running the script I also received these errors:
This would lead me to thinking I can ignore the warning and also assume it is not related to the degraded boot pool.
My course of action would be to to
edit: almost forgot another confusing thing: I did not receive an email alert or an alert in the GUI.
Hardware:
TrueNAS-SCALE-23.10.1 Supermicro X10SLL-F, i3 4130, 16 Gb ECC RAM, Seasonic Prime PX-750 Data pool: 2*8Tb mirror Data pool 2: 1*8Tb boot pool: 1*128 Gb SSD UPS: Eaton Eco 650
pool: boot-pool state: DEGRADED status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P scan: scrub repaired 0B in 00:00:31 with 0 errors on Sat Feb 17 03:45:32 2024 config: NAME STATE READ WRITE CKSUM boot-pool DEGRADED 0 0 0 sdc3 DEGRADED 0 0 0 too many errors errors: No known data errors sdc3 -> sdc3
########## SMART status report for sdc drive (INTENSO SSD : AA000000000000001840) ########## SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x0032 100 100 050 Old_age Always - 0 5 Reallocated_Sector_Ct 0x0032 100 100 050 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 050 Old_age Always - 1632 12 Power_Cycle_Count 0x0032 100 100 050 Old_age Always - 14 160 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 0 161 Unknown_Attribute 0x0033 100 100 050 Pre-fail Always - 100 163 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 8 164 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 10351 165 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 86 166 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 1 167 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 42 168 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 5050 169 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 100 175 Program_Fail_Count_Chip 0x0032 100 100 050 Old_age Always - 0 176 Erase_Fail_Count_Chip 0x0032 100 100 050 Old_age Always - 0 177 Wear_Leveling_Count 0x0032 100 100 050 Old_age Always - 0 178 Used_Rsvd_Blk_Cnt_Chip 0x0032 100 100 050 Old_age Always - 0 181 Program_Fail_Cnt_Total 0x0032 100 100 050 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 100 100 050 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 050 Old_age Always - 3 194 Temperature_Celsius 0x0022 100 100 050 Old_age Always - 40 195 Hardware_ECC_Recovered 0x0032 100 100 050 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 100 100 050 Old_age Always - 0 197 Current_Pending_Sector 0x0032 100 100 050 Old_age Always - 0 198 Offline_Uncorrectable 0x0032 100 100 050 Old_age Always - 0 199 UDMA_CRC_Error_Count 0x0032 100 100 050 Old_age Always - 0 232 Available_Reservd_Space 0x0032 100 100 050 Old_age Always - 100 241 Total_LBAs_Written 0x0030 100 100 050 Old_age Offline - 27485 242 Total_LBAs_Read 0x0030 100 100 050 Old_age Offline - 2999 245 Unknown_Attribute 0x0032 100 100 050 Old_age Always - 116886 No Errors Logged Most recent Short & Extended Tests - Listed by test number # 1 Short offline Completed without error 00% 1487 - # 2 Extended offline Completed without error 00% 1381 - SCT Error Recovery Control: SCT Error Recovery Control command not supported
Collecting data, Please wait... Partition 1 does not start on physical sector boundary. Partition 2 does not start on physical sector boundary. Partition 1 does not start on physical sector boundary. Partition 2 does not start on physical sector boundary. Partition 1 does not start on physical sector boundary. Partition 2 does not start on physical sector boundary.
fdisk -l
shows the errors in regard to zd0
which would be my zvol for my pfsense VM.Code:
Disk /dev/zd0: 12 GiB, 12884918272 bytes, 25165856 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 16384 bytes I/O size (minimum/optimal): 16384 bytes / 16384 bytes Disklabel type: gpt Disk identifier: 9D15D700-C5E8-11EE-BAA7-00A0982879CB Device Start End Sectors Size Type /dev/zd0p1 40 532519 532480 260M EFI System /dev/zd0p2 532520 533543 1024 512K FreeBSD boot /dev/zd0p3 534528 2631679 2097152 1G FreeBSD swap /dev/zd0p4 2631680 25163775 22532096 10.7G FreeBSD ZFS Partition 1 does not start on physical sector boundary. Partition 2 does not start on physical sector boundary.
zpool clear
the boot pool and wait what happens. The main reason for my question here though is: Why is the status degraded if no error is logged? Where can I check?edit: almost forgot another confusing thing: I did not receive an email alert or an alert in the GUI.
