Boot gets stuck sometime
no_connection
DL360 G7
After an update or reboot it gets stuck on that forever with a reset (ctrl alt del don't work) as only option. Then it seem to boot just fine.
I'm not really too fussed about it but still.
Kieeps
I get the same on my dl380 g7, never on my microserver g8 though so I just figured it was something weird with the g7 :smile:
no_connection
It happened again. Even if G7 would be a bit weird it's still a SCALE problem as no other OS I have put on them does this.
Who knows what is needed to fix it tho so I'm not holding my breath unless something jumps out. If I remember Ill keep posting in case it helps debug something in the future.
