Chris McDowell
- Feb 3, 2017
I have a non critical FreeNAS setup that is running non-ECC Ram. I am trying to do as much of this remotely as possible. I have a USB thumb drive for the Boot device.
Running pool status -v I get..
I feel that this is more of a dying USB drive than anything. I am wondering where I can access that file and try replacing it with a different copy.
I am also having another issue where a SuperMicro SATA DOM that I got as a replacement for another that died is disappearing. I had it working today after a reboot but after trying to mirror the boot pool it just disappeared. Is there anything I should be doing to get more details on the issue.
This is a Core i5-3330 with 8GB of non-ECC RAM. Boot device is a 16GB USB Thumb Drive. Running 11.1-U1
pool: Main state: ONLINE scan: scrub repaired 0 in 0 days 03:47:51 with 0 errors on Sun Feb 11 03:47:51 2018 config: NAME STATE READ WRITE CKSUM Main ONLINE 0 0 0 gptid/913c108a-65f5-11e7-980a-d43d7e93454f ONLINE 0 0 0 gptid/7c87d28d-6c10-11e7-b65d-d43d7e93454f ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0 days 00:04:57 with 1 errors on Wed Feb 14 07:00:19 2018 config: NAME STATE READ WRITE CKSUM freenas-boot DEGRADED 0 0 0 da0p2 DEGRADED 0 0 0 too many errors errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/11.1-U1@2017-07-10-21:27:08:/data/freenas-v1.db
