azurelinuxagent tries to run and fails on local Hyper-V VM
GurliGebis
Hey,
I'm just testing out TrueNAS SCALE in a Hyper-V VM.
It seems like it thinks that Hyper-V = Azure, and then tries to run the Azure Linux Agent, which fails (most likely since it is not on Azure).
I have attached a screenshot of the error it shows on the console.
Do let me know if this is not the right place to report the issue, or if anything else is needed.
morganL
Captain Morgan
Administrator
That's worth reporting as a bug... the Azure agent was added, but it was not tested when running on Hyper-V. The goal in general is to replace Hyper-V, but you are just testing.
GurliGebis
Yeah, I have just installed a test machine in Hyper-V.
My guess would be that you need to detect if running in Hyper-V, and if that is the case, somehow detect if it is running in Azure or locally, and then only enable it if in Azure.
morganL
Captain Morgan
Administrator
"report a bug" is a menu item above.
WE use a jira.ixsystems.com system.
