First, I'll describe the issues I have, and then I'll point to several other threads that seem to be related, but they are all unsolved.
I *am* able to use FreeNAS 11 on Hyper-V, but it definitely had some quirks, and there seems to be an intermittent issue when FreeNAS boots up.
My specs:
FreeNAS 11.0-U4
Hyper V Server 2016 (Core, not windows server 2016, aka the free version)
ASRock EP2C602-4L/D16
LSI SAS 9207-8I
6x WD NAS RED drives
96GB ECC RAM
First, things that will always trigger a panic during boot. And by panic - its not a nice/normal FreeBSD panic that dumps a core. Rather, it is a stack trace that shows up on the screen, and it just continues forever.
1) A generation 2 vm
2) Enabling SR-IOV on any network adapter
After setting up a normal gen 1 vm without SR-IOV, during boot, during the phase that says:
nvme cam probe device init
This is where the panic, if it occurs, will occur. Sometimes, even after a successful boot, a reboot of the freenas vm will trigger the panic. One time the only way I could avoid it is by rebooting the entire Hyper-V host.
Looking at the trace, it does seem like it may be related to some Hyper-V specific code, as 'vmbus_chan_recv_pkt' and usually shows up. I've seen also 'vfs_mountroot' and 'kdb_trap' also show up.
I have no answers to this at this time, which is unfortunate, since not having a reliable freenas boot up is very frustrating. But, since I'm sorta working, I'll deal with it. I need certain features of Hyper-V for my guests, namely Remote FX.
I'll gladly send my entire freenas.vhd file to any FreeNAS dev that will care to reproduce/diagnose this issue.
I also downloaded FreeBSD-11.0 (the .vhd file) from FreeBSD.org and it worked without a problem.
Here are other links I've found that seem to be the same problem
https://forums.freenas.org/index.ph...enas-won-t-boot-when-adding-processors.58447/
https://forums.freenas.org/index.ph...nless-a-cd-drive-is-present-in-hyper-v.56187/ <- this link had a good mitigation, which seemed to help a bit. (Adding set kFreeBSD.kern.cam.boot_delay="50000" to grub bootloader)
Possibly related bugs:
https://redmine.ixsystems.com/issues/25524 <-- this one has a hint that I'll try next - to disable guest services on the vm
My specs:
FreeNAS 11.0-U4
LSI SAS 9207-8I
96GB ECC RAM
