ToastedBread
- Aug 22, 2016
Background: Upgraded system to Corral, upgraded encrypted volume, worked fine for a few weeks. Boot drive failed, waited a long time, replaced boot drive and installed FreeNAS 11. Now I am attempting to re-import my encrypted ZFS pool.
When attempting to re-import the volume, I use the .key file and insert my password as follows:
I click ok, it does its thing and then returns this error:
So I did some more research and came across this thread: https://bugs.freenas.org/issues/23444. I followed the commands from this image.
Everything goes fine until the "python3" command. I type it in and a console appears. So I exit the console and type the next command:
this creates even more issues. Instead of running as intended, I get this error:
From here I am lost. This is a fresh install. I have a backup with Crashplan, but I experienced issues with the crashplan plugin before Corral, so I don't know if I can actually access them.
Thank you in advance for your help.
python3 get_volume_keys.py
