Spannerman
- Nov 12, 2012
I have just upgraded to FreeNAS 9.2 and uploaded the Transmission plugin, but I want to set its IP address to 192.168.1.110 and port as 53029 (as I used to have for historical reasons on my previous transmission on FreeNAS 8.3). I can't seem to find any guidance online but I looked at the settings for the transmission jail and saw the default IP is 192.168.1.1. No sign of where the port assignment may be as a separate box though. So I tried setting the IP as 192.168.1.110:53029 there (on the same line)which was accepted, but the Transmission Web GUI is not then available on this address. It worked OK on default. I tried rebooting the server to see if that helped but then things got worse as I could no longer access the FreeNAS GUI. Its on a static IP of 192.168.1.107 with a forwarding port of 30292. Gateway is 192.168.1.25. I ended up having to do a factory reset and reload the configuration as both web GUI's were then inaccessible on their expected IP addresses. I'm assuming I've created a conflict of some kind and I am missing something simple so thought I'd ask here. I've been enjoying remote access to my server via these ports for a long time now so its much less convenient at the moment. Appreciate any guidance - my skill level is probably dangerous amateur :) . Thanks
