I just installed a transmission jail.
The port was immediately open (I have UPnP enabled for my whole network)
(1)
To make sure it works with manual port forwarding I disabled the transmission option "Use port forwarding from my router" and cleared the UPnP rule in pfSense above.
I then made the NAT Port Forward pictured...
(2)
which automatically opened the port on the WAN interface as pictured..
(3)
Tested with an external checker just to make sure it wasn't transmission just remembering it was open..
(4)
So it worked for me, both using UPnP and manual port forwarding
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
