Gnrl Kitty
- Dec 25, 2016
I've just installed transmission. I've done nothing to the plugin or jail. However, when I go to the management page for Transmission, I get the following message:
I've used the shell in the jail to open settings.json and neither 'rpc-whitelist' nor 'rpc-whitelist-enabled' are in the file. This is not the first time I've installed Transmission on this machine. I just uninstalled it trying to fix something else, and this problem didn't occur then. It's only happening now that I've reinstalled it.
What could cause this?
403: Forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
