Marcet
- May 31, 2013
Hi all,
I run a newly build NAS based on ASRock Rack C2750D4I motherboard (detailed configuration in my signature). This motherboard has a passive heatsink and I started to look closely at the temperatures thru the IPMI web dashboard.
The motherboard stays around 38°C with a room temperature of 22°C.
The thresholds for CPU temperature are set to those defaults :
But, the sensor event log shows events in the UNC, UC and UNR zones :
Intel specs sheet for this processor shows a max temp before shutdown to 97°C.
Beside this CPU temp concern, all the rest of the system is cool, the HDD temps for exemple are :
Trying to find a solution, I've build a bracket for two 80mm fans. They are blowing toward the passive fan.
The results shown here are after this modification (the number of UNC, UC and UNR observed was way greater before).
Any advice of what I should do ?
- Upper Non-Recoverable (UNR) : 90°C
- Upper Critical (UC) : 85°C
- Upper Non-Critical (UNC) : 80°C
14 02/18/2016 22:01:35 CPU Temperature Temperature Upper Non-Critical - Going High - Deasserted 13 02/18/2016 22:01:26 CPU Temperature Temperature Upper Non-Critical - Going High - Asserted 12 02/18/2016 22:01:15 CPU Temperature Temperature Upper Non-Critical - Going High - Deasserted 11 02/18/2016 22:01:08 CPU Temperature Temperature Upper Non-Critical - Going High - Asserted 10 02/18/2016 20:02:31 CPU Temperature Temperature Upper Non-Critical - Going High - Deasserted 9 02/18/2016 20:02:25 CPU Temperature Temperature Upper Critical - Going High - Deasserted 8 02/18/2016 20:02:24 CPU Temperature Temperature Upper Critical - Going High - Asserted 7 02/18/2016 20:02:23 CPU Temperature Temperature Upper Critical - Going High - Deasserted 6 02/18/2016 20:02:21 CPU Temperature Temperature Upper Non-Recoverable - Going High - Deasserted 5 02/18/2016 19:50:11 CPU Temperature Temperature Upper Non-Recoverable - Going High - Asserted 4 02/18/2016 19:50:10 CPU Temperature Temperature Upper Non-Recoverable - Going High - Deasserted 3 02/18/2016 19:50:08 CPU Temperature Temperature Upper Non-Recoverable - Going High - Asserted 2 02/18/2016 19:50:06 CPU Temperature Temperature Upper Critical - Going High - Asserted 1 02/18/2016 19:50:06 CPU Temperature Temperature Upper Non-Critical - Going High - Asserted
Current Temperature: 32 Celsius Power Cycle Min/Max Temperature: 27/33 Celsius Lifetime Min/Max Temperature: 2/35 Celsius
