Madd Martigan
- Jan 31, 2014
I wanted to post to the community my experience with the new Asrock C2550D4I motherboard running FreeNAS 9.2.
First, the hardware:
Lian Li Mini ITX Tower (6 3.5" drive bays and one 5.25" drive bay which I populated with a 4x2.5" HDD fixed bracket that is vented in the front)
RAIDMax 730W PSU
Asrock C2550D4I CPU/Motherboard Mini ITX
16GB (2x8GB) Kingston 240 pin DDR3 RAM (KVR16N11H/8)
4x Western Digital Black 2TB SATA 3.5" HDD
2x Western Digital Red 2TB NAS SATA 3.5" HDD
3x 500GB Hitachi/Toshiba 2.5" HDD
I realize that I have a mish mash of drives but for what I want/need this will work fine. I am running this as a iSCSI target for my VMware ESXi host. I have configured the 3.5" drives as a single RAIDZ disk group with just over 8TB usable in the ZVOL and the 2.5" drives as a single RAIDZ disk group with around 850GB in the ZVOL.
I have the network interfaces configured on two different VLANs but connected to a single iSCSI portal. On the ESXi host side I have two vswitches set up with a single NIC assigned to the VMKernel port on each. I have them both assigned to the software iSCSI adapter (I am using a Intel NIC on that side too. I tried using a Broadcom dual port NIC with it's hardware assisted iSCSI capabilities but I had purple screen issues with it every time I tried so I gave up). I have both ends configured to use 9000 byte jumbo packets. I am also using Round Robin for path management so I am getting active I/O on all paths assigned.
All of my testing/migration to this configuration so far has shown about 500Mbps of utilization on each of the NICs on each end. I am getting right around 95MBps read and write out of this configuration. However, the testing/migration basically involves migrating from local SATA spinning disk to the FreeNAS server.
The entire configuration has proven to be very functional. CPU on the FreeNAS server seems to be hovering right around 45% to 55%.
Overall it seems to be a very good performer. Just wanted to post it up here so that everyone knows that it does work fine.
RAIDMax 730W PSU
