ASRock C2550D4I COM1 disabled?
yel
I'm trying to activate COM1 under BIOS (under Advanced->Serial Port Console Redirection). The COM and SOL options on the top are greyed out and indicated as Disabled, and I can't change the console redirection options for either. The Windows EMS option on the bottom is active. Screenshots I've seen of this BIOS screen suggest that I shouldn't see this greyed out COM & SOL.
Has anyone experienced this and knows how to fix this? I've flashed the BIOS to the latest update v2.30.
thanks
fd0
thanks
I am experiencing the same with the C2750D4I that came with my FreeNAS Mini, that was purchased from iXsystems a while back.
I am unable to get a serial console working
pro lamer
Wasn't it a jumper on the motherboard? (Edit: it's moot, see below)
Sent from my mobile phone
Redcoat
pro lamer
Thank you, but please tell us your source for that suggestion.
I can't say from the top of my head but I'll look and post back.
pro lamer
I can't find it, sorry...
I might have confused motherboards
fd0
My other system has same motherboard and does not have this issue.
Both BIOS as well as FreeBSD-11.2 installed on it show an active COM1 in the menu Advanced->Serial Port Console Redirection
I wonder what is wrong here
fd0
In my case, I raised a bug with iXsystems, which they accepted.
MoBo will be replaced:D \o/
fd0
thanks
report to where you purchased it.
ASRock uses 3 year or longer warranty
