Mark Renouf
- Mar 11, 2017
I am building a FreeNAS system, and just assembled components tonight.
Everything was working great. Drives (5) online and memory correct. Installed FreeNAS onto a USB drive. Right around the time I was rebooting to start it up for the first time I was adjusting the position of some wire bundles, and adding a few last zipties. The system powered off and back on itself a couple times.
I assumed I had a loose power connection, or something else going on, so I snugged and rechecked all the power connections. Nothing seemed too out of place.
I've continued eliminating possibilities for the past 3hrs now:
Wiped CMOS,
Powered on through IPMI web interface.
Removed all but one stick of RAM and ensured it was seated solidly.
Thinking my PSU might be acting up, I checked all the voltages with the green turn-on wire shorted, and everything checks out (12v was 11.8v, but that's in spec).
I went so far as to try a second known-good PSU, and the results were the same.
The system fan spins up, the later speeds up slightly, then slows down again. That's IT!
IPMI comes up and works fine. Nothing else.
This system was working fine 3hrs ago. I'm so confused.
The thing that has me thinking dead motherboard now is the lack of voltages on the sensors. What could have happened to this board?
Is there anything else I could try?
ASRock 2570D4I,
Crucial 32GB (8GB x 4) ECC Unbuffered RAM
...all other components disconnected!
Haaaaalp?!
Wiped CMOS,
ASRock 2570D4I,
Haaaaalp?!
