graylion
- Dec 28, 2019
Intel i5-13500
128 GiB RAM
3*6 TB WD Red in 1 zvol
TrueNAS-SCALE-23.10.1.3
so I had made a booboo with my network config, ie activated kubernetes and installed an app before adding the bridge for virtualisation. Eventually I gave up and reset the config.
After rebooting and this time configuring my network correctly, I am faced with the following phenomenon:
No apps show as installed, but when I list available apps, adguard home shows as installed. I get offered to install a second instance and get alerted of a name conflict. So it seems to be there. I don't seem to be able to connect to it though.
so my question is how can I either make the thing fully visible to kubernetes or elsewise remove it?
Thanks!
128 GiB RAM
Thanks!
