Faluzure
- Oct 9, 2014
So I'm letting my system burn in but I still check it out periodically. The UPS I'm using is the APC Back-UPS ES 725 Broadband and it works (I've done the "on-battery" tests). Even the 'upsc' command spits out all the details about the UPS. However, I've noticed in the logs (plus the kernel security emails) that I periodically get the following:
Nov 11 09:18:46 FreeNAS root: Unknown USB device: vendor 0x051d product 0x0002 bus uhub3
AND:
FreeNAS.HOME kernel log messages:
> ugen1.4: <APC> at usbus1
> ugen1.4: <APC> at usbus1 (disconnected)
For the 1st issue, I've been looking in the FreeNAS Bugs site and found 2 things related.
The bug was mentioned here: https://bugs.freenas.org/issues/3768 , which involved upgrading the NUT subsystem. But for some the issue still persisted. But the issue was closed, as it was referred to another bug tracker: https://bugs.freenas.org/issues/2548
In #2548, it doesn't list the same kind of problem. It's a driver error problem on that one but still involves a NUT subsystem upgrade. The target version is 9.3. My question is, is there any issues with upgrading NUT by itself? Will it affect anything that 9.3 does, when it's released?
As for the latter issue, I'm not sure what's going on there. It does it for < 1 second and only happens every couple hours. Looking around on the forums, I've found others having this issue, but it's accompanied by either a "connection failure/connection refusal" or "communications lost" message. I get none of those. Just simply the < 1 second usb disconnections. I've checked the cable and even tried a different USB port for the APC, but I still get those messages periodically. Although it's not hurting anything, I would just like to get rid of (fix) random log messages pertaining to the UPS. Any comments on that message?
AND:
