I have a BR1500G APC UPS (http://www.amazon.com/dp/B003Y24DEU/?tag=ozlp-20) I have the it connected by the USB to Catx cable that comes with the unit. I hit the services, UPS to turn it on & get this message:
Any idea how to get this working?
Thanks,
Rich
Thanks,
Rich
Jan 21 15:54:17 freenas notifier: Can't start /usr/local/libexec/nut/(null): No such file or directory Jan 21 15:54:17 freenas notifier: Network UPS Tools - UPS driver controller 2.7.3 Jan 21 15:54:17 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Jan 21 15:54:17 freenas notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Jan 21 15:54:17 freenas notifier: Starting nut_upsmon. Jan 21 15:54:17 freenas notifier: kill: No such process Jan 21 15:54:17 freenas notifier: UPS: ups (master) (power value 1) Jan 21 15:54:17 freenas notifier: Using power down flag file /etc/nokillpower Jan 21 15:54:17 freenas upsmon[8871]: UPS [ups]: connect failed: Connection failure: Connection refused Jan 21 15:54:17 freenas upsmon[8871]: Communications with UPS ups lost Jan 21 15:54:17 freenas notifier: Starting nut_upslog. Jan 21 15:54:18 freenas notifier: Warning: initial connect failed: Connection failure: Connection refused Jan 21 15:54:19 freenas notifier: Stopping nut_upslog. Jan 21 15:54:19 freenas notifier: Waiting for PIDS: 8884. Jan 21 15:54:19 freenas notifier: Stopping nut_upsmon. Jan 21 15:54:43 freenas upsmon[8862]: upsmon parent: read Jan 21 15:54:43 freenas notifier: Waiting for PIDS: 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871, 8871. Jan 21 15:54:43 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Jan 21 16:00:05 freenas autosnap.py: [tools.autosnap:71] Popen()ing: /sbin/zfs snapshot -r "Pool@auto-20160121.1600-2w" Jan 21 16:00:05 freenas autosnap.py: [tools.autosnap:71] Popen()ing: /sbin/zfs snapshot -r "FNPool@auto-20160121.1600-2w" Jan 21 16:08:09 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Jan 21 16:08:09 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Jan 21 16:08:09 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid). Jan 21 16:08:09 freenas notifier: Will not 'restart' nut because nut_enable is NO. Jan 21 16:08:09 freenas notifier: Will not 'restart' nut_upsmon because nut_upsmon_enable is NO. Jan 21 16:08:09 freenas notifier: Will not 'restart' nut_upslog because nut_upslog_enable is NO. Jan 21 16:08:28 freenas notifier: tcgetattr(/dev/ugen0.3): Inappropriate ioctl for device Jan 21 16:08:28 freenas notifier: Network UPS Tools - APC Smart protocol driver 3.1 (2.7.3) Jan 21 16:08:28 freenas notifier: APC command table version 3.1 Jan 21 16:08:28 freenas notifier: Driver failed to start (exit status=1) Jan 21 16:08:28 freenas notifier: Network UPS Tools - UPS driver controller 2.7.3 Jan 21 16:08:28 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Jan 21 16:08:28 freenas notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Jan 21 16:08:28 freenas notifier: Starting nut_upsmon. Jan 21 16:08:28 freenas notifier: kill: No such process Jan 21 16:08:28 freenas notifier: UPS: ups (master) (power value 1) Jan 21 16:08:28 freenas notifier: Using power down flag file /etc/nokillpower Jan 21 16:08:28 freenas upsmon[13205]: UPS [ups]: connect failed: Connection failure: Connection refused Jan 21 16:08:28 freenas upsmon[13205]: Communications with UPS ups lost Jan 21 16:08:28 freenas notifier: Starting nut_upslog. Jan 21 16:08:28 freenas notifier: Warning: initial connect failed: Connection failure: Connection refused Jan 21 16:08:33 freenas upsmon[13205]: UPS [ups]: connect failed: Connection failure: Connection refused Jan 21 16:08:33 freenas upsmon[13205]: UPS ups is unavailable Jan 21 16:08:35 freenas notifier: Stopping nut_upslog. Jan 21 16:08:35 freenas notifier: Waiting for PIDS: 13227. Jan 21 16:08:35 freenas notifier: Stopping nut_upsmon. Jan 21 16:08:53 freenas upsmon[13204]: upsmon parent: read Jan 21 16:08:54 freenas notifier: Waiting for PIDS: 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205, 13205. Jan 21 16:08:54 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Jan 21 16:11:08 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Jan 21 16:11:08 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Jan 21 16:11:08 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid). Jan 21 16:11:08 freenas notifier: Will not 'restart' nut because nut_enable is NO. Jan 21 16:11:08 freenas notifier: Will not 'restart' nut_upsmon because nut_upsmon_enable is NO. Jan 21 16:11:08 freenas notifier: Will not 'restart' nut_upslog because nut_upslog_enable is NO.
