ArcticWolf_11
- Aug 24, 2017
Hello, new to FreeNAS and I just came to a realization after building my FreeNAS box that cat 6 1Gbps would take like 2.8 days to transfer a little over 400GB of data from my current SSD (also doesn't help that I just realized that I had a 100mbps switch in the middle of it...). After that transfer, it will probably be the most intensive thing that the server will do (file transfer from my PC to the NAS in a while). I don't access the files/SSD often but when I do, it's just usually to add more files for storage. I don't plan to back up my computer to it either, since all my important files will be on the NAS and not the desktop. I am also thinking of installing applications on it so that I don't have to worry about reinstalling them on a reset. Also will not be storing videos and movies for plex use either. So pretty much just really light usage I guess. Due to this I was thinking that a 10Gb NIC would be appropriate for this since my FreeNAS server is an old HP dl360e Gen8, I was thinking of buying this https://www.amazon.com/HP-Connectx-2-Interface-671798-001-666172-001/dp/B0178CNZ9U and this https://www.amazon.com/Cable-Matters-Multimode-Duplex-Fiber/dp/B00U7UP49K to hook up FreeNAS to my computer directly. Don't want the entire network to be able to access it, just my PC so 2 NICs would be just fine (and also to save money because i'm a little short on it after buying drives >.<) Will that NIC be fine for 10Gbps FreeNAS as I saw in the comments on amazon that on FreeNAS it is limited to 1Gbps? Am I safe to assume that 10Gbps will be more than enough for me as I only have 4 8TB WD Reds, like is this math right? 10Gbps = 1GB/s, My SSD = 550MB/s, 4 8TB WD Reds in RaidZ2 = like 400MB/s??? One last thing, how fragile are Fiber cables? Like I know not to bend them 90 degrees because there's glass in them and how do I connect them to the NIC, is it just like ethernet? Thanks, and I really need help on this so that I don't buy incompatible hardware. :)
-EDIT- Also just now realized that if I did that, the box wouldn't be able to access the internet for updates. Can I just plug the Ethernet cable into the box once in a while to update it? Also if I connect it straight to my PC, would it get an IP so I can connect to it using the webgui or would I need to put it through my router to do that?
P.S, Sorry for the giant block of text... >.<
