Bidule0hm
Server Electronics Sorcerer
 - Aug 5, 2013
In heavy RF environments we used to have to run network cabling in conduit. Faraday cage *that*. :p
"Heavy RF environments" hmm, lets see... Ah, something like your backyard?:
Example: my Media center recordings start having noise recorded with the picture from my dehumidifier in the basement, not even the same circuit. That's not illusion.It's fixed now , but I am not sure how I fixed it, just moving stuff from each other as far as possible. If this was not observed on the picture I wouldnt even know is there, could be a data cable keep dropping packets.
That's because it's most probably radiated noise, not conducted noise ;)
Damn modern gear, insufficiently shielded!
Radiated noise from cables, not the appliance itself ;)
Copper is expensive... Modern gear is (mostly) crap from China manufactured at the lowest price possible... So yeah, not two things you can merge together I guess :D
If you want something well designed, built to last, serviceable, ... look for a used thing pre 2000's or even pre 1990's, or something recent but from the industrial world where you can't really cut corners :)
Ok, simpler solution: wrap the whole house in copper foil :D
Somehow, just wrapping the interface between S/FTP cable and shielded jack seems like a cheaper option.Ok, simpler solution: wrap the whole house in copper foil :D
I can't help pointing out
I can't help pointing out that light is electromagnetic radiation. Irrelevant, perhaps, but pedantry dictates.
